- Joined
- 12 Oct 2024
- Messages
- 277
- Reaction score
- 63
- Country
Hi all,
My extension is now having the soffits done. The inner block skin is noticeably higher than the outer skin. The wall insulation finished at the top of the outer skin. I asked the builder how the top of the inner wall would be insulted given there is a good 30cm above the wall insulation to the top of the wall plate. He has cut more cavity wall insulation to take it further up past the top of the outsider skin but it now stops at the bottom of the wall plate.
This means the wall plate will not be insulated so would be a cold spot at the top of the inner wall? I asked how he would address this and he said he doesn't usually do it.
The rafter spars are in the way at 600mm intervals and he said building control don't want the tops of cavities closed off. I had suggested rolling loft insulation down over the final top bit of the inner skin to basically close off the cavity and maintaining insulation. Perhaps using baton between the rafters, or some kind of tray, to maintain ventilation from the soffits and in to the attic.
Thoughts? Does this matter?
The cavity wall insulation is a 90mm type with a 10mm gap (in practice there isn't much of a 10mm gap!)
