Many happy returns.
Sockets?I did say ideally , you don’t want them in a dangerous position .( New builds tend to have sockets around 1200mm above floor level.)
Yeah.Sockets?
Really?
The tops of my light switches (new ones in the parts of the house extensively "re-modelled" a few years ago) are at about 1380mm
The sockets are about 460mm.
In kitchens , (subject of this post .)Sockets?
Really?
In the main they are looking at wheelchair use, and one can nearly touch the ground in a wheelchair, but the axle height of wheelchair wheel is the height where damage can happen due to wheelchairs. So 150 mm from the floor should be avoided as that is about the height of the wheel centre of a self-propelled wheelchair, so 300 mm means in the main out of harms way.Switches, sockets, stopcocks and controls have their centre line between 450mm and 1200mm above floor level and a minimum of 300mm (measured horizontally) from an inside corner.
Approved Document M - not the law - Guidance; feel free to ignore.Part M building regulations does not seem to make much sense
I did, my mother in a wheelchair opened my eyes to the daft bits, like it seems one's arms grow when you leave the house, or why would the highs in domestic premises be higher than commercial?Approved Document M - not the law - Guidance; feel free to ignore.
I don't think it's that far off for above-counter/bench sockets in a kitchen or workshop etc. In such situations, I would imagine that around 1000 mm is probably about the absolute minimum.Never seen sockets that high.Newbuilds, sockets and switches tend to be around 1200mm
Kitchen surfaces are usually 880mm plus top so 910-930mm. If the bottom of the backbox (my typical measurement reference) were at 1000mm the bottom of the socket would be around 990mm and the L/N pins at 1010mm, a typical moulded plug requires around 60mm below the pins to avoid severe bending or 950mm leaving only 20-40mm of clearance. Try a Masterplug with 2.5mm² cable and that becomes next to no clearance.I don't think it's that far off for above-counter/bench sockets in a kitchen or workshop etc. In such situations, I would imagine that around 1000 mm is probably about the absolute minimum.
That, was more about ease of installation. You could drill a hole in the skirting, and push a cable through into the under-floor. The alternative, was to chop out the plaster above the skirting, then down the back of the skirting.In my teenage years sockets were often immediately above skirting boards or indeed in the mid of the skirting board itself. This was very common - I guess folk did not like seeing sockets (and switches too sometimes) and ease of use took second place.
The bedroom light switch was usually just inside the door of the bedroom, some had a pullswitch over the bed too (or instead of) , some did not.
