Nonsense, nothing like what might be considered engineering operation.
Eh?Raising ground levels is a "engineering operation" in planning terms and may require planning permission
That's just bonkers and grasping at straws . 1. see for what you can do : https://www.planningportal.co.uk/pe.../paving-your-front-garden/planning-permission and 2 : the only guidance is for 30cm above the ground level, which it is not so is considered to be withing PP rights.Raising ground levels is a "engineering operation" in planning terms and may require planning permission. There are no set measurements, so it's a matter of fact and degree as to whether the work should have require permission.
The other issues resulting from this work are not covered under any statutory legislation that you could use, nor under any common law civil action.
Planning law covers "development". And this is defined as "the carrying out of building, engineering, mining or other operations in, on, over or under land, or the making of any material change in the use of any buildings or other land.
Taking a dip out of your drive is an engineering operation which requires PP?Planning law covers "development". And this is defined as "the carrying out of building, engineering, mining or other operations in, on, over or under land, or the making of any material change in the use of any buildings or other land.
For buildings there is "Operational Developmnent" for new building, or "material change of use" for alterations to buildings.
For land, there is "Engineering operations" for physical alteration of land - in this context, raising of levels.
Engineering operations are not defined, although have been determined in various appeals and court cases which have become precedent.
It's fact and degree as to whether the OP will be an engineering operation. In this case, not only the raising of the ground level on the street scene, but also there is an element of retaining of the land - which has been previously determined to be an engineering operation.
So that's the only possible way under planning law I can see that the OP may have a chance.
Dunner be daft. They'd need to be 300mm above the natural ground level to get Planning even remotely interested.Technically Woody has a valid point
I've wrote it twice - fact and degree.Taking a dip out of your drive is an engineering operation which requires PP?
Nonsense.
Fluffing out posts with ambiguity doesn't help. Especially where Planning matters are concerned.fact and degree.
