A 2kw heater cant suddenly decide to be a 3kw.....can it?
Even more pointless jabbering!
The thing about a shower, is that they only run for a matter of minutes
He thinks every single question posed should be a learning experience for the poster. It is MANDATORY that the poster learns something.
What you need to do is get a spec sheet for the screws and the ply. Multiple the tensile strength of the screws and the ply, then divide by 8.482. Add the humidity level for whatever day you intend to do the work, then subtract it. What number do you get? That'll give you the answer you're looking for.
A 32 amp will run at 36 amps forever ish, over that it will trip instantly, I think (memories going),![]()
I have a 9.5Kw which has been running on a 6mm/32amp MCB, for many years and without any issues.
I did laugh because Harry made me laugh, you was jabbering on about nothing....probably.Well this is a 40A load, and since Harry reports
it won't trip instantly at 40A. But will it run forever (ish) at that current?
Why, when I tried to find out what informs Harry's view that 40A through a 32A MCB will be fine because showers "only run for a matter of minutes" did you laugh and agree with Harry when he described that as pointless jabbering?
Quite simply, no one, but no one, will run a shower for in excess of one hour.
In fact most will be in, and out within minutes - that is the point of a shower, speed for most people.
The worst that can happen is that if you exceed the 'on time', is that the MCB/RCBO might eventually trip. Inconvenient, if you happen to still be in that shower, but perhaps a reminder to get out?
All MCB's/RCBO's, in the same range, are built with the very same internal components, able to carry the maximum current of the same range, all that varies is the sensing/trip components, suggesting that overheating due to overload, should not be an issue.
As in a time you'd more likely state in minutes than fractions of an hour? Yes.
As in only a few minutes? No.
What are you jabbering on about, do you even know?
Mr Morqthana its been quiet a time. I can recall you saying that you had me on block so I don't think there is a valid reason of quoting and replying to you but as you have mentioned my name I would like to insist. You said I was out and done or maybe blocked, like there was no way back or no reason to speak right? It feels like you wanted a reaction but still want to act above it, like poking at something and walking off like your hands are clean. If I was so out the way, why are you dragging me in sideways like this? Say things straight please or don’t say them at all this halfway mess just shows you’re not done.In fact I'd like to open my question out to SUNRAY, diy_fun_uk, Jurassicspark and whoever the 1 other person was who thanked Harry Bloomfield for saying I was jabbering.
Nothing wrong with that There is absolutely nothing wrong with looking into how long a shower might run and whether it can run long enough to trip the MCB. If there’s a space between something running forever and tripping immediately it doesmake sense to understand exactly where the shower fits.If there's a space between running forever ish and tripping instantly, what is wrong with looking into how long a shower might run, and whether it might run for long enough for the MCB to trip?
Depends on the shower and it depends on the type of MCB. Would running 40A continuously through a 32A type B MCB trip it? And when would it trip the MCB? Look at the trip curves.Maybe it won't - maybe that time is several hours. Maybe it's 20 minutes.
Well what really matters isn’t debating the length of a shower but whether the system is built to handle normal use safely. So spending too much effort on interpreting “a matter of minutes” is a pointless when the bigger picture should be about proper installation and reliable protection.I don't know. But I do know that maybe what Harry meant by "a matter of minutes" merited examination.
Well how do you know that its "as in a few minutes" and how do you know it’s not just a few minutes? People’s shower habits can be very different some might take quick showers and others take longer. Saying it’s only a few minutes assumes everyone is the same, which isn’t true. Saying its for like a fraction of an hour assumes everyone is the same, which isn't true. Without real data or measurements, you can’t just decide the shower only runs for a short time.So to SUNRAY, diy_fun_uk, Jurassicspark and ano - what was your real reason for agreeing that I was jabbering when I asked?
What exactly do you mean by "fine"Do you really think that it doesn't matter how long "a matter of minutes" is because it's always going to be the case that a 40A shower on a 32A MCB will be fine?
Don't bring me into your row, all I did was agree with someone who knows what he's talking about.So to SUNRAY, diy_fun_uk, Jurassicspark and ano - what was your real reason for agreeing that I was jabbering when I asked?
Stop jabberingIn fact I'd like to open my question out to SUNRAY, diy_fun_uk, Jurassicspark and whoever the 1 other person was who thanked Harry Bloomfield for saying I was jabbering.
Do you really think that it doesn't matter how long "a matter of minutes" is because it's always going to be the case that a 40A shower on a 32A MCB will be fine? Or was there another reason for agreeing that I was jabbering?
No not really.A 32 amp will run at 36 amps forever ish, over that it will trip instantly, I think (memories going),
