Garage roof joist/beam advice
15 Aug 2025
Hi all,
I'm looking at options to raise the height in part of the garage to fit a golf simulator. I plan to rip out that makeshift room at the back and thought possibly that back area would be best so the front area could remain usable as a garage, open to ideas though.
Currently there are 3 solid beams spanning the width of the garage and a number of joists. The joists are currently 2.6m high and would ideally need raising to around 3m in the area used to swing. The main 3 beams are fairly evenly spaced and at least one would need moving horizontally or removing to provide enough space to swing.
Is this likely to be possible before I go ahead and get a structural engineer out? Any general suggestions or thoughts?
Thanks in advance!
All things are possible if you have deep enough pockets.
You may need a steel frame: best get an SE out for a preliminar chat.
