Appreciate I'll be getting an electrician in to do this but looking to understand what I'll be asking them to do.
We currently have a standard electric cooker (hob and oven in one freestanding unit). It connects to an outlet on the wall behind it via a simple, unswitched, twin outlet wall plate. The wiring back to the fuse box from the wall plate is 10mm twin and earth via the cooker switch in the wall and is protected by a 50A RCBO. Oven is connected directly to the wall plate with no other in-line fuse. I'm assuming this is normal and safe (though I wonder what is protecting the cooker cable before it gets to the fuse inside the cooker).
In our new kitchen, we're going ot have a built in hob in the same location as the existing cooker and a built in oven about 2m away in a tall cupboard. Oven requires 16A. Total current for hob and oven is well within the 10mm cable capacity (and also below the 50A RCBO limit).
To build in a bit of future flexibility (maybe add a microwave above/below oven later on), I was thinking to ask for a 4mm twin and earth spur from the original cooker outlet plate over to a new/second outlet plate for the oven. I'm assuming this would need to be fused locally to the main outlet plate (at level appropriate for the 4mm cable spur) and then again at the new outlet for the oven?
Attempt yo draw it all out below:
Thanks.
Thanks.
