- Joined
- 25 Jul 2022
- Messages
- 18,975
- Reaction score
- 1,624
- Country
Only problem with that is the gearbox might not be full. No point changing the oil if you don't fill it to the correct level.Not sure there is a level line. I was just going to measure what comes out and put the same amount back in.
My workshop guide does not show the diagram of the drain and fill locations, so i have to work that out. And yes, I have educated myself already on the need to check the fill valve/nut before draining!
Ka , and fords generally are topped up until the oil is level with the bottom of the filler plug.
Which means the car needs to be as level as possible, not easy if the car is on a jack.
It is manual, not auto ?
