- Joined
- 15 May 2023
- Messages
- 55
- Reaction score
- 0
- Country
I've built an outbuilding, and am in the process of cladding it now. It's concrete block all round (had to incorporate a retaining wall into it), which i've battened and clad with timber on half of it. On the other half, down the fence side, I can't bring myself to spend the massive cost on charred timber (like the rest of it) for a side that isn't very visible.
Trying to think of the cheapest cladding solution that also doesn't look terrible - could I use cement fibre boards, edges sealed with silicone, painted in something like black zinsser all coat? This would be on top of battens fixed to the concrete block, leaving a continuous airgap of 25mm, vented top and bottom. Something like this:
www.cladco.co.uk
Any reason this wouldn't work, or any better similar priced options would be great to know.
2.4m Fibre Cement Backer Board for Construction, Exterior Grade
<h2>Discover Fibre Cement 2.4m Multipurpose Backer Boards</h2> <p>Whether you are looking to board walls or floors (pre-tiling), fibre cement boards can make this job much easier. 2.4m lengths boards can be used on ceilings, around fires, internally and externally.</p> <p>Due to being a...
