Water valves under boiler - Baxi 800 - identify...
28 Oct 2025
I have a baxi800 and an trying to ready myself to balance the 7 radiators in house I have just moved room . I may need to re pressure the system so in this pic are the levers for sure .
Can anyone identify them ?
What is the yellow one ?
Your help be so much appreciated.
(I have another question as have to balance the system as some of the Rads have the TRV on the wrong side. the trv's are bindirectional)
Thanks so much for info !!! What a site this is !!
I have one issue as I'm red green colour blind ....
I dont see any green in the picture .....
I attach a picture of all the levers. Yellow = gas (I ain't going near that)
so the other three are water and middle one of them (that looks half way down ) is to release water into system ?
Thanks so much . prepare for more damned fool questions .
just ordered a Lazer Heat thing to assist project balance ... this when I'm confused as on some rads TRV is on wrong side where water flowa in. i.e the hot water comes in via lockshield valve .....
seems illogical to balance a radiator in this state
I don't know why you keep saying trv is on the wrong side. If non bi-directional then fair enough, but you said they are.
good point
BUT
I have just moved into the house and 4 of the heads trv, didn't work. they were non functioning. nothing to do with pin . The pin on all the TRV valves works fine. iv bleed all rads - all ok.
So I've been looking at the system and I bought 4 TRV heads that fit. I realise that just putting on a new head doesn't change the valve so the valves may or may not be bi-directional....
(The four heads I bought come with the valves and are bi-directional but I have not fitted the valves)
All I know is last night's check the first two radiators the pipe that heated up first upstairs in the two rooms was on the lockshield side.
There are five downstairs which I am trying to find the sequence.
I have an infrared heat monitor arriving today. to do the balancing which I think is 12° C on the outflow side.
What I'm saying is it seems a logical to me to have put these valves in on the side that is the outflow. I have to either assume they are bi-directional or not.
good point
BUT
balancing on a condense boiler is actually around 20 degrees which on majority of existing installations is more or less impossible to reach even 12 degrees can be a struggle at times
understood.
I will this eve try and balance the upstairs with the new thermo device ....
I expect the Niagara falls to come down on me but will report .....
A while ago you kindly told me what lever under my boiler does what.
Im just trying to add all the dots as have to remove rad to flush and add maybe 2 TRV valves.
I attach a pic and wandered what exactly the levers do, which I identify with a "?"
There is one on the left I don't know what does and wandered if anh if these will help with removing valves , rads.
2 outside valves are the flow and return so the valves isolate the system's flow and return from the boiler. The valve 2nd from the right isolates the cold supply into the boiler or into the filling loop, usually position dependent.
The left one is the heating flow and the levers isolate the boiler from the rest of the system.
Thanks guys !! Trust me us ignoramussss so appreciate this info.
Re the left one - the heating flow ?
What is that ? Is only to do with hot water not the rads ?
The flow to the radiators, not the hot water taps.
Ok can you look at the picture again as I have from left to right . Need to hammer this down in my head.
-Flow to rads
-Gas
-Flow to ? With lever to re pressurise
( Do I assume this is simply the flow to top up from mains - water in?)
-Return from rads
Sorry to be a numb head .....
I know nothing of these systems as come from a wonderful oil converted old aga with a boiler for water (no heating) ...... I pine for it .....
