My partner lives in a 3 year old new build. She is looking to get an EV charger installed. I have an Easee One that's been removed from another house and would like to use this.
In the garage there is a square black wiring 'box' with a twin and earth cable that apparently goes back to the CU. The house was sold as 'EV charger ready'. I'm not sure of the size of the cable but it is definitely beefy. I'd be very surprised if it's not up to the job.
I've posted a picture of the CU below. Does there appear to be sufficient capacity to wire the charger in? I'll be getting an electrician in to do the job but just wanted to avoid any shocks (!) in terms of extra equipment/labour needed.
I did speak to an electrician informally and all they said was that they'd need to install EV Ultra cable back to the CU as you need the data cables for load monitoring. Is that necessary? I have an identical Easee One at my house and the electrician was fine installing it without any extra monitoring.
The heating is all gas. Usual high power devices on downstairs socket circuit are Microwave, toaster, kettle, instant hot water tap, washing machine, heat pump dryer. Hob is I believe ceramic (glass top, heats up red) not induction.
Thanks!
Ted
Thanks!
Ted
