Good morning,
I've got a Texecom Premier Elite 88 with 4 Capture D20 PIRs, each wired as EOL on their own zone. They all have selectable resistors and are set to the Texecom setting (2k2/4k7). 3 of them work fine, but one of them goes to Tamper (>100K) when triggered (by both PIR and Microwave) instead of Active (see attached).
If I swap the front modules around, the fault follows the module which makes me think this isn't a wiring fault. All PIRs have the same jumper and resistor settings.
Is it most likely I've got a faulty PIR? What actually causes the tamper to go off as I can't see a contact switch in the unit?
Any advice or tests I can conduct from software or with a multimeter would be appreciated!
