- Joined
- 27 Sep 2022
- Messages
- 304
- Reaction score
- 23
- Country
Thanks, will change it to proper guage.1st off, that's the wrong gauge,
It looks like it but I thought I'll ask anyway.It could also be an outlet for a gauge
Thanks, that explains the double check valve I have has a provision of installing a pressure guage, so I don't need to use PRV to seal it.lating double check valve on the cold mains side
This is what has been bought on ebay store. I am trying to put it to seal my system from OV.valve on both ends of a filling loop to allow it to be fully isolated
Yes, it can.presume the OV boiler can be run sealed
Would it be Ok if PRV is set at 1.2 - 1.5 cold?That and a 3bar PRV is too high for a sealed system
Understood, I wouldn't leave it at autofill and set the prv at 1 - 1.5bar for filling or topping up the system.I wouldn't use an always open autofill
The PRV is pointless, you don't need it.Understood, I wouldn't leave it at autofill and set the prv at 1 - 1.5bar for filling or topping up the system.
It can go anywhere, it's just to fill the system.can this PRV connection for filling the system be made at that connection?
