thats a fair pointGood advice. And also make sure your use of indicators is exemplary, making it better by one car on the road helps
most cars seem to have automatic headlights these days -driving in what might be described as "light dusk" most car headlights tend to be onOn this subject auto on LED lights are st-upid idea.
Cars coming down a motorway off ramp waiting for a gap in the traffic on a fast running roundabout underneath the motorway then an auto on LED lights car looks like it is flashing you to pull out when its auto - on lights come on under the dark motorway bridge.
My 'new' car is 10 years old and is the first I've owned with these auto lights. I can see the logic in this feature, given it's not unusual to see folk driving with no lights on around town when it's dark.most cars seem to have automatic headlights these days -driving in what might be described as "light dusk" most car headlights tend to be on
and I find LED headlights in night time can be blinding on dip -so bad that often you cant see the road beyond the oncoming car
They're completely out of control. Manufacturers (especially BMW and VW among others) are deliberately tipping them up, so their driver can see and tells everyone how wonderful their headlights are, and to hell with everyone else.and I find LED headlights in night time can be blinding on dip -so bad that often you cant see the road beyond the oncoming car
It's a shame that auto lights are so necessary.On this subject auto on LED lights are st-upid idea.
From the testers manual. I've highlighted the bit that may have been misunderstoodThey're completely out of control. Manufacturers (especially BMW and VW among others) are deliberately tipping them up, so their driver can see and tells everyone how wonderful their headlights are, and to hell with everyone else.
The MOT light alignment test just isn't being done. I heard one tester on a radio programme about it, he said they adust the dashboard dipping control to make them pass. This is just wrong and is a massive misunderstanding - they should be correctly dipped when set at zero, which requires adjustment under the bonnet. The dashboard adjuster should normally be set at 0, and only needs to be adjusted if there's a lot of weight in the back.
We bought one of ours used with LED/HID headlights, with a fresh MOT by the previous owner before selling. They were horizontal when dipped, and lighting up the trees above on full beam, utterly ridiculous. I adjusted them down, you just need a level surface, a wall in front of you and an allen key. Oh, and you also need to actually care about whether they're aligned properly, which most people don't.
I find Teslas way too bright, have one following you at night, blinds you via the mirrors even
Yep, the tester on BBC local radio specifically said they adjust the dashboard adjuster, they set it to 2 or 3 to align it correctly for the test. Then when they see it next year the stupid owner has set it back to 0. All the owner's fault apparently, his idiotic preaching was meant to be some sort of public information announcement to tell people to leave it set as the MOT tester left it.If driver’s beam aim controls are fitted, you should test the beam aim without altering the control setting. If this would result in failure for beam aim being too low, you should re-check the beam aim with the control set at its ‘highest’ position.
My posher one does the adjustment automatically, just the same. But there are still overall adjusters, in my case it's two allen key adjusters on each light - one for up/down, another for left/right. These should be routinely adjusted after failing an MOT due to the alignment, but it almost never happens.I don't have a manual adjustment on mine, it has suspension height sensor arms, front and rear, and adjusts the beam aim, at each switch on, based on it's sensors. With the lights on, they do a quick shuffle, up and down.
Great. When it works. I had a Range Rover behind, I could sense flickering as it adjusted but it was still melting my eyeballs.My up beam works automatically.
Car comes towards me, my light dips on RH side, and stays on full directly in front of me.
When I come up behind a car, my lights stay up to the right and left, and above, so the car in front is in a little square of it's own, dipped.
When I have the above, behind a car, and I get an oncoming car, I get lights to the left and above the car in front.
This can be quite mesmeric, when you first see it, all happening, need to look at the cars, as well......![]()
The biggest issue with headlight aim, and beam pattern is aftermarket LEDs put into old style headlamps. Over 90% of all headlamp failure in my experience, and that of other testing stations that I talk to (nationwide).Yep, the tester on BBC local radio specifically said they adjust the dashboard adjuster, they set it to 2 or 3 to align it correctly for the test. Then when they see it next year the stupid owner has set it back to 0. All the owner's fault apparently, his idiotic preaching was meant to be some sort of public information announcement to tell people to leave it set as the MOT tester left it.
It just shows how bad things are, when the people doing the tests don't know what they're doing.
I'm absolutely certain that the manufacturers are deliberately setting them too high. They won't need an MOT for 3 years so nobody will intervene.
The worst are the newest cars. Rarer but often even worse are the old pimped up wrecks with an Amazon headlight upgrade kit.
If we had a government that was in any way bothered, they'd send VOSA out to randomly stop and test cars, compile a list of whose cars are worst, name and shame them and ban them from sale until they're fixed. Also require existing cars to have an alignment check at an MOT garage. But none of that will happen.
