Insulate garage door and fill gaps at side
13 Feb 2025
I would like to insulate a bifurcated garage swing up (up and over) door. I have breathable roofing membrane, mineral wool, bits of 150mm kingspan block insulation and various glues.
Could I use very small screws to attach the breathable roofing membrane to the inside of the garage door, pin mineral wool (or kingspan) to the mineral wool then lap the membrane over on the other side? The door swings up so I don't want to add too much weight to the door mechanism.
I also want to seal around the side and top of the door frame as it is very gappy at the top a bit of at the side
Invest in some Soudal low-ex fixing foam. Glue the PIR to the door and use the same foam to fill any gaps around the frame.
Would this Screwfix 'Soudal Adhesive Foam Hand-Held 750ml' work? It says it can be used externally. The glue/adhesive needs to be able to withstand condensation (that may form on the inside of the door)
I have 3/4 of a can of 'EVO-STIK Sticks Like Sh*t Adhesive, All Weather adhesive' (says it can do temperatures down to -40oC) can I use this aswell to stick the PIR to the garage door?
Is the soudal adhesive foam reusable if I put some gaffa tape over the end after gluing a test piece of insulation to the garage wall interior?
Slice it up into slips about 50mm thick, foam the back of the door with expanding foam, foam the slip with expanding foam, leave 2 minutes then press the slip onto the door
Once you get into a pattern with the process you'll have an area of foam on the back of the door going tacky, and several slips on the go at once
When you're done the kingspan will be bonded entirely to the door with expanding foam. Expanding foam is more or less the same thing as kingspan so in essence you're generating something similar to the metal skinned insulated roof panels you see on commercial buildings, albeit one sided
You can spray the inside edge with carpet glue, wait for it to go tacky, then bond your roofing felt to it
Far less likely that it will form condensation once it's insulated
I wouldn't personally use this to adhere kingspan to the door
Would this work to stick kingspan to the interior of a metal garage door: https://www.toolstation.com/soudal-soudabond-easy-adhesive-foam-gun-grade/p37023?
By 'expanding foam' do you mean adhesive glue like this Soudal adhesive: https://www.toolstation.com/soudal-soudabond-easy-adhesive-foam-gun-grade/p37023? This Soudal adhesive can set at temperatures of up to -5oC which is needed this Winter as it's less than 5oC outside.
Would this work as carpet glue: https://www.toolstation.com/stick2-contact-adhesive/p47790? Basically spray this over the inside surface of the kingspan and the edges then glue breathable roofing membrane to the kingspan
Yes, products like that, or even the cheaper regular expanding foam. If you lay it out on both surfaces and give it a few minutes to expand and go tacky, it bonds well. You'll know if you've left it too long because it skins over and won't stick to you when you touch it
Be aware that gun grade foam needs a metal applicator gun into which the canister is screwed. I'd go as far as to say that they're useful to have kicking around even if you only plan on using them for one job, if they're about twenty quid; they are more controlled with their foam delivery and are self sealing.
You don't unscrew partially used canisters from the gun, just leave them on, unless you don't plan on using it for months (in which case remove the foam can and screw on a can of cleaner, run it though as per instructions)
See TS items 28840 and 30746
I have a metal application gun (TS item 28840). I can leave the Soudal gun grade adhesive opened and on the gun after gluing on a test piece of block insulation (to make sure the block insulation sticks 1st). I would use the cheaper expanding foam but I need a low application temperature of lower than 5oC which it is now
Just use the low-ex Soudal ADHESIVE foam with its re-useable stopper. Use 75 or 100mm foil tape to seal any tight joints. Use foam and foil tape to seal any bigger joints.
Whilst the polymer adhesives are good, the foam is way better in this instance.
The insulation is st
I have just stuck on the breathable roofing membrane to the garage door using the carpet glue. I now need super strong tape to go over all edges and all roofing membrane overlaps. What sort of tape should I get? Something like 3M, Gorilla Tape, etc
Overlaps, use your polymer adhesive. Edges, I'd just use expanding foam again. Line it out and let it go tacky/expand (but not skinned over) then press the membrane onto it
