How Good are New Toilets?
Family home is on a septic tank. After, well really during covid and the toilet paper shortage they had a Shataf fitted (and used) which reduced their toilet paper concumption grately. Now having become used to the idea and practise of washing over wiping themselve clean they rarely use paper. Noticably their tank is emptied far less and the outflow from the tank (to a soakaway) in much cleaner and ceratinly less grey. Even the wife who was a bit 'off' about using the Shataf is now OK with it and we have fitted one on our toilet.
We still get people who think we are wierd and have funny toilet habits 'cause we have one.
We have a bidet with just a mixer tap fitted. However I've been considering one of those Shataf jobs. A bit awkward on the install due to the tiling. A friend of mine has them installed on all his toilets in his newly renovated house. I asked him if he had fitted them to WRAS standards. It appeared not from his answer. Although I don't think a separate break tank is necessary on the cold supply I think double check valves on both the hot and cold supply should do it. May I ask if you have fitted anything similar on you installation.
But they used about 30 litres of water per flush. Efficiency is about doing more with less, so they're technically the opposite
It may surprise you that fresh water is in short supply in the modern day and age - https://environmentagency.blog.gov.uk/2024/03/21/meeting-our-water-needs-for-the-next-25-years/
.. and like many things finite in resource the answer is not "carry on burning through it at the same rate and find ways to make more", it's "use less"
I've just installed a grohe skate in-wall slimline cistern that's 2 inches thick and puts about 3 litres into the bowl on the small button. The bog is the cheapest back to wall one that Victorian plumbing supplied and amazingly it's enough to clear the bowl of all reasonable solids..
How much TP do you use per wipe? Does the bowl clear if you do a halfway flush when it's less full of paper? Could be an indicator you're using too much
If no, then perhaps the answer to your double flush routine is to replace the bowl?
Oh, I fully appreciate that those old toilets were made for an era when there were fewer concessions towards water conservation. It just so happens that I remember that impressive gravity-fed gush and the maelstrom that followed it with nostalgic affection, and compare it ruefully with the pathetic "swish" of my bog in a box. As for TP, the paper always disappears whatever the quantity used, whereas the skiddies don't. So the more I think about it, the more I'm angling towards a "glue in the poo" situation. Guess my next move is to find out what's upset her.
That's the only way to do it correctly.
Yes, it looks like there's no way around it. If the hose was restricted from entering either the toilet or bidet pan, it wouldn't be any use.
It makes you wonder how people retrofit those Japanese bidet toilet seats that are available.
In the hospitals where I have worked the toilet supply was always tank fed for both hot and cold. They also had a device called a Closomat on the ladies wards. These were a combined toilet and bidet. There were foot operated switches to activate the retractable water jet and the heated fan for drying off. I personally thought that they were very unsanitary, due to the potential for fallout on the water jet.
I recently had the conversation with a couple of guys that say they had been fitting them for years and never knew that it was illegal to do so without the separate tanks.
Saying it would be very hard for the nozzle to fall into the loo and the rare instance of it syphoning out seemed to be enough to get them to just fit it. I bet that in the thousands of UK Muslim households where they are fitted, none of them have air gapped sources.
The problem is that check valves do not pose a barrier to bacteria that can migrate across.
Dare I say... Like the English Channel!
Umm, that made me think. Had to go and have a look at both the installation and check the invoices.
Cause the parents house is (was) plumbed before mains water was installed only the kitchen has mains water, the rest of the house is supplied by a tank in the loft, independant of the mains. According the invoice there is a one-way (check) valve combined with the stop tap.
Ours has a double check valve / stop tap.
Ours has a double check valve ?stop tap.
Different category of contamination risk...
I bought two rimless toilets from Victorian plumbing
In the main they are ok, sometimes flush doesn't fully work and strangely leaves behind one or two squares of toilet paper
But the main issue I have with them is the flush and refill valves, seem to be crap Chinese product and I am not able to get the refill valve apart to service the washer. One of them has started squealing a bit when refilling and I would like to investigate. Any ideas?
Modern toilets are generally much better due to improved bowl and flush design, and a good one should clear the pan properly on a single flush. That said, performance still varies a lot between models.
Flush design and installation tend to matter more than age alone, and poor pipe runs can make even a decent toilet perform badly. Since water saving isn’t a priority for you, it’s worth choosing a model with a strong full-flush rather than the absolute lowest water use.
design i use "wall hung toilet" and its good and look aesthetic too.
As of brand, all are good.
just select better model and maintain long.
One thing I have noticed that due to being rimless my new toilet has a shelf up near the top, I think it is this that is causing what I have noticed - namely pee on the underside of the seat at the front.
Now I know it's not the males in the house doing this, it must be hitting the shelf when the women pee and bouncing up.
Ewww...
No doubt I will be blamed for it once they notice...
