Smart meter home display question
18 Jan 2006
Cumbria
In a previous post, I described at length the myriad of problems I was having after switching suppliers to Octopus. Well, toward the end of last year, things seemed to have been sorted, my meters were being remotely read correctly and all the previous billing errors seemed sorted. Then around August/September time this year, I realised I hadn't had an email statement for a couple of months so I checked the statements in my account and realised that Octopus had not been getting live readings from my meters since june and my bills were being estimated since then. Nothing has changed in or around my house to cause any signal loss.
I contacted Octopus and they asked a few questions about siting and possible signal blockers and said they would investigate. I also said it would be helpful if they told me about any such problems so that I could send manual readings. In December, I looked at my statements again and saw that my useage was still being estimated. What annoys me is that they are way out in their estimation and because there is no communication, the pricing info in my home display is also well out of date.
I contacted Octopus again a couple of weeks ago and it was as if this was the first time they were aware there was a problem! They then asked me the same questions they asked a few months back. One of the questions asks whether there is any obstruction between my gas and electricity meters that could affect communication between them. My home display is displaying both gas and electricity useage and is updating gas info at half hourly intervals. From this, can I assume that communication between the two meters is ok?
We're with Octopus (no smart meters), and for a long time they were asking for meter readings monthly. Recently we realised that they stopped asking "some time ago".
I must check their statements -the cynic in me says they might be over-estimating the estimates to soften us up for having a smart meter.
I just been forced to have a f****** 'smart meter' - day reading are OK but the night readings are way, way out - like 350%! Nothing has changed in the overnight usage, previously it was find 12 units per night now it's around 40 units even if the big MAN was taking power for all 7 hours that is only 21 units.
Definitely not happy.
Still on dumb meters with octopus. I log into the app once a month and give them customer readings - then check the bill to ensure they’ve used my readings. Takes me a couple of minutes each month
Who needs a smart meter
The gas meter sends data to the electricity meter at intervals, not in real time.
The home display connects to the electricity meter and gets all of its data from that, mostly real time or certainly every few seconds.
The electricity meter is what sends everything to the energy supplier (via the DCC) and receives data from them including pricing.
No comms between gas and electricity meter = no gas readings but everything else works.
No comms between meter and display = display does not work but everything else does. Display is optional.
No comms between meter and supplier = things in the building all work but nothing gets sent to the energy supplier or received from them.
In your case it's the electricity meter-supplier communication that is a problem. Either the signal in your area is junk, the comms module on the meter is busted, or there is some configuration error with the meter-DCC-energy supplier.
Thanks for the replies. It was as I thought, the remote display gets its info from the electricity meter. The question about whether there is anything that could block the signal between the meters is irrelevant as my remote display is updating correctly.
As far as I know, OctopusWatch gets it's data from Octopus, rather than directly from your meter, so if you splash out the couple of quid or so it costs, you can easily check every couple of days if Octopus are getting readings from your meter.
I find it a really useful app myself.
It doesnt matter what your in home display is reading or communicating, if the supplier cannot access both gas and electricity readings you will not get an accurate bill.
I am with Octopus and used to work for National Grid and then EDF. Send Octopus an email/contact form stating “COMPLAINT” then give the facts, what has been done, what is not working and what you would like to resolve your complaint. e.g. confirmation that they are getting readings from both gas and electric or whatever it is that needs fixing.
In my case it took them 2 weeks to replace the electric meter that was not communicating. I had my own Complaint Assistant with her personal company email address so that we could communicate progress/resolution directly.
Having worked in the industry 15 years prior to retirement Octopus are one of the better suppliers overall.
Good luck.
Or, at no cost, ask Octopus to supply you with one of their pick gadgets. That plugs in, connects to your internet, and relays your instantaneous consumption, straight to Octopus's servers. You can then check on their website, and see what you are using, updated every 10 seconds. Graphs of both electric, and gas consumption, appear next day, on the same site.
Is that the Home Mini?
Suppliers get the smart meter readings via the DCC who receive the data via mobile phone or long range radio (South vs North/Scotland).
One can sign up to Bright or similar apps to get the same data pulled from the DCC... That'll quickly prove if the smart meter Comms unit is talking to DCC.
If it is the Octopus can pull the stored data...
If it isn't they can investigate why not... and there are potential solutions to fix such comms problems.
and
are worth a read.
It seems, as far as smart meters go, you are up north. North-South devide smart meter.jpg The Octopus Pink thing may help, but because smart meter wise I am down south, I don't know how it all works up north.
I have tried to read my smart meter and failed, there are so many displays, Smart meter reading 4.jpg and no instructions as to what they all mean, I know I should have three readings, one peak and one off-peak, and one export, but I have failed to work out which of the reading are which, I rely on the app to tell me, so if my signal stopped working they would need to send a meter reader I could not provide them with readings, as there are so many.
I had to have a smart meter to be paid for export, but all I see on the IHD is zero, or export, so the display to me is useless, what would help is a state of charge display for battery, that I could see at a glance, I have to use phone or PC to see if spare energy I can use to do washing etc.
Seems from adverts we should do gardening at night, think my neighbours may object!
Eric, you seem confused! The pink gadget/Home Mini, works no matter where in the country you are. They tap into the smart meter readings, exactly the same as the In Home Display would, and directly connect to your wifi. Unlike your meters, which send a single, large batch of readings, which can be up to 24 hours old - they send a constant stream of up-to-date data, updating every 10 seconds.
You gain the advantage, of having access to the data up-to-date data via an API, with no need for the IHD, or just the live basic data on their website. Octopus gain the advantage of also knowing exactly their customer's consumption - live, rather than delayed 24 hours or more.
