Replacing Parquet with LVT Flooring - BC Required?
7 Jan 2026
Hi all. I have a question about replacing the flooring in my home in the UK (not the sub-floor). I live in a 1960s ground floor flat where currently there is parquet wooden flooring installed. The sub-floor is concrete. I intend to replace the parquet with Luxury Vinyl Tiles (LVT) flooring. The sub-floor will not be touched or replaced in any manner - it's simply a matter of removing the parquet wooden tiles and laying the LVT on top. Does this require a Building Regulations application?
BC doesn't need contacting.
Check the lease of your flat, just in case it's got some restrictions on the kind of floor you can install, although I have only seen restrictions regarding hard floor which you already have, so it should be fine.
Be aware that the bitumen adhesive commonly used for old parquet tends to contain asbestos fibre. This will be a relatively small amount of the least hazardous type and can be managed with simple precautions - you won't need specialist firms nor its complete removal, but all the same care should be taken and specific methods used.
Any flooring firms used should be 'asbestos aware', not necessarily licenced, and the old flooring blocks will require special disposal, and the remnant bitumen should be sealed or scraped and removed.
Thanks Johnny. Yes, that's correct. There's no restriction in the lease for flooring (y)
People pay a fortune to have real wood parquet floor fitted. What is wrong with what you have.
Thanks a ton Woody! With this additional information, you've literally saved me going ahead with ripping off the flooring and making a huge Health and Safety mistake. The bitumen adhesive is black in colour and might most likely contain asbestos like you highlighted. I've now sent a sample of the adhesive substance for lab tests and awaiting results.
If it comes back positive, I might just go ahead and install the LVT flooring on top of the parquet flooring. It seems to be stuck down pretty well so hopefully will not cause issues for the LVT. And the flooring company doesn't cover DIY LVT installation so I'm not getting their warranty anyways. Time will tell if I come to regret this decision.
The misses is not very fond of it. It's a beautiful floor no doubt but she'd like something "contemporary"
Herringbone is currently rather fashionable! (which almost put us off having it in our new kitchen - but we have always liked it, honest!)
Personally, I think you’d be mental to get rid of that.
I have parquet in my through lounge and hallway.
OMG you need a new wife not a new floor :LOL: that floor would cost you a fortune to put down and herring bone is a big trend right now. Sand back and re do with a clear hard wax oil and it will all look a lot lighter and cleaner and fresher and last forever.
Parquet always reminds me of school assembly - sitting cross legged on the cold, hard hall floor, hoping not to be called up to the front for public scolding from some minor transgression.
Be gone with it.
Be aware that all plastics have a fairly huge thermal rate of expansion. If your floor is exposed to areas where the sun can beat down on it, be very careful. Also make sure whoever fits it adheres to the manufacturers guidelines for installation temperatures. Installing in winter is risky because if the plastic flooring is installed too cold, it is likely to belly if heated later.
The coefficient of thermal expansion of LVT flooring is about 0.07mm/degree/m so across a 5m room and 30 degrees of temperature change (heating off in winter v. sun beating down in summer) you get 0.07 x 5 x 30 = 10.5mm expansion/contraction.
Like others, I'd have the existing floor professionally refinished.
The test results from the lab came back negative for asbestos. I've decided to keep the parquet intact and just install the LVT on top. As and when we grow to appreciate the parquet more we can easily revert back to it in the future.
Thanks all for your advice.
