I'm somewhat struggling to work out what you are trying to say hereI was thinking that , you can get an outside light switch that tells you to do that isnt there?
Yes, I admitted it is non-ideal but, for someone who was 'in the know' it would tell them whether the outside light was on or off without having to look outside!
Those neons do eventually die, but even those which are on continuously (which many are) usually last for a few years (and can usually be replaced).
Yes sorry that didnt make much senseI'm somewhat struggling to work out what you are trying to say here![]()
Yes, that's how it should be.
Yes, a very long time ago it was green, rather than the current green/yellow
No - it is earth. That theoretically leads to another possible 'clever' suggestion, but it's somewhat 'naughty' so I probably shouldn't mention it![]()
I really should not be saying this, but ....That earth cable therefore isn't spare so I don't think your "naughty" suggestion would work, but just out of interest, what is this intriguing "naugty" suggestion?![]()
I have decided to use a normal light switch and keep the double pole switch for another use. Yeah, that doesn't sound very safe, even if I could understand itI really should not be saying this, but ....
... the earth cable doesn't need to be 'spare'. (if you were thinking of oversleeving the bare earth wire at its ends and using it as a neutral, that would be so very naughty that even I would not contemplate it).
However, if you connected the (real) earth to one side of the neon (as well as to the metal parts of switch), with the other side of the neon connected to the 'switched live' (most likely your black, but possibly the red), then the neon would work as you would like, but there are reasons why it would theoretically be undesirable (although not 'unsafe') to do that!
Fair enough. AsI said, to do what I described would be 'safe', but it would slightly increase the chances of 'nuisance tripping' of any RCD or RCBO protecting the circuit.I have decided to use a normal light switch and keep the double pole switch for another use. Yeah, that doesn't sound very safe, even if I could understand it![]()
Some do seem to last 'forever'. However, it is not (in my experience) uncommon for those which are lit for most of the time to strat flickering after a few years, and then eventually die.30+ years is not unusual..
Interesting theory. Some electronic loads will draw a current which has a DC component, but I wonder what situations you're thinking of which could result in the supply (voltage) having a DC component?They tend to blacken the glass, rather than actually fail, due to any DC component on the mains supply.
... then the indicator should turn on when the outside lights are off ...
It does, but there's a fair chance that it would work (and nothing lost or 'dangerous' if it doesn't).Depends on the type of outside light.
"Not unsafe" is merely an opinion.I really should not be saying this, but ....
Would it indeed? Would the courts concur?Fair enough. AsI said, to do what I described would be 'safe'
I suppose it is, as is the great majority of what people write here (including your 'opinion' that my statement was an opinion!)."Not unsafe" is merely an opinion.
If my opinion is correct, then no court would be asked whether or not they concurred. However, if my opinion is incorrect, and if the matter somehow got before a court, then I would have to ask the court the same question that I have asked you above.Would it indeed? Would the courts concur?
