I'm somewhat struggling to work out what you are trying to say hereI was thinking that , you can get an outside light switch that tells you to do that isnt there?
Yes, I admitted it is non-ideal but, for someone who was 'in the know' it would tell them whether the outside light was on or off without having to look outside!
Those neons do eventually die, but even those which are on continuously (which many are) usually last for a few years (and can usually be replaced).
Yes sorry that didnt make much senseI'm somewhat struggling to work out what you are trying to say here![]()
Yes, that's how it should be.
Yes, a very long time ago it was green, rather than the current green/yellow
No - it is earth. That theoretically leads to another possible 'clever' suggestion, but it's somewhat 'naughty' so I probably shouldn't mention it![]()
I really should not be saying this, but ....That earth cable therefore isn't spare so I don't think your "naughty" suggestion would work, but just out of interest, what is this intriguing "naugty" suggestion?![]()
I have decided to use a normal light switch and keep the double pole switch for another use. Yeah, that doesn't sound very safe, even if I could understand itI really should not be saying this, but ....
... the earth cable doesn't need to be 'spare'. (if you were thinking of oversleeving the bare earth wire at its ends and using it as a neutral, that would be so very naughty that even I would not contemplate it).
However, if you connected the (real) earth to one side of the neon (as well as to the metal parts of switch), with the other side of the neon connected to the 'switched live' (most likely your black, but possibly the red), then the neon would work as you would like, but there are reasons why it would theoretically be undesirable (although not 'unsafe') to do that!
Fair enough. AsI said, to do what I described would be 'safe', but it would slightly increase the chances of 'nuisance tripping' of any RCD or RCBO protecting the circuit.I have decided to use a normal light switch and keep the double pole switch for another use. Yeah, that doesn't sound very safe, even if I could understand it![]()
