- Joined
- 8 May 2017
- Messages
- 10,673
- Reaction score
- 2,875
- Country
Is the base of that fitting metal or plastic ?
Metal, so one earth coming from the light fitting (it's attached to the ceiling bracket)Is the base of that fitting metal or plastic ?
Ok ,so the base plate is earthed via the ceiling bracket ?Metal, so one earth coming from the light fitting (it's attached to the ceiling bracket)
Yep!Ok ,so the base plate is earthed via the ceiling bracket ?
You could connect up using wago's as you suggest ,or insulated terminal blocks if space is an issue.
Don't know if they're a newer thing but some shops local to me have them, look handyNever seen a 10 way wago?
Would you recommend these over my idea? Or doesn't entirely matter?
I hadn't read it, just had a quick flick through....whichever way you like should be fine.Would you recommend these over my idea? Or doesn't entirely matter?
Sorry to hijack, you may have not even read the thread
