Using a double pole swich for outside light
Yes, I admitted it is non-ideal but, for someone who was 'in the know' it would tell them whether the outside light was on or off without having to look outside!
Those neons do eventually die, but even those which are on continuously (which many are) usually last for a few years (and can usually be replaced).
i can tell if the lights are on by the position of the switch, but it means you need to look at it carefully and be within a short distance of the switch. with the indicator, I can tell from a distance away. I often forget to turn the lights off outside once I have turned it on, so I am relying on the neon indicator to remind me to turn it off!
Yes, that's how it should be.
Yes, a very long time ago it was green, rather than the current green/yellow
No - it is earth. That theoretically leads to another possible 'clever' suggestion, but it's somewhat 'naughty' so I probably shouldn't mention it :-)
Thanks. I have only ever seen the earth cable sheath in green and yellow or just yellow. Google says that old wiring had a green sheath for earth, but thought I should check.
I have added an earth cable from the light switch to that hole in the wall as I saw a video that says a metal light switch should be earthed and there is no earth wire in that arrangement from the light switch, but that old light switch is plastic and the new one I installed is metallic.
That earth cable therefore isn't spare so I don't think your "naughty" suggestion would work, but just out of interest, what is this intriguing "naugty" suggestion? :ROFLMAO:
I really should not be saying this, but ....
... the earth cable doesn't need to be 'spare'. (if you were thinking of oversleeving the bare earth wire at its ends and using it as a neutral, that would be so very naughty that even I would not contemplate it :-) ).
However, if you connected the (real) earth to one side of the neon (as well as to the metal parts of switch), with the other side of the neon connected to the 'switched live' (most likely your black, but possibly the red), then the neon would work as you would like, but there are reasons why it would theoretically be undesirable (although not 'unsafe') to do that!
I have decided to use a normal light switch and keep the double pole switch for another use. Yeah, that doesn't sound very safe, even if I could understand it :D
Fair enough. AsI said, to do what I described would be 'safe', but it would slightly increase the chances of 'nuisance tripping' of any RCD or RCBO protecting the circuit.
30+ years is not unusual..
They tend to blacken the glass, rather than actually fail, due to any DC component on the mains supply.
Some do seem to last 'forever'. However, it is not (in my experience) uncommon for those which are lit for most of the time to strat flickering after a few years, and then eventually die.
Interesting theory. Some electronic loads will draw a current which has a DC component, but I wonder what situations you're thinking of which could result in the supply (voltage) having a DC component?
Depends on the type of outside light.
It does, but there's a fair chance that it would work (and nothing lost or 'dangerous' if it doesn't).
I had intended to type a 'probably' into what I wrote, but my typing fingers seems to have ignored that instruction :-)
"Not unsafe" is merely an opinion.
I suppose it is, as is the great majority of what people write here (including your 'opinion' that my statement was an opinion!).
Your comment implies that your opinion differs from mine, so I would be interested to hear in what way you would consider it 'unsafe'. As I have written, the worst I can think of is a slight increase in the risk of an RCD/RCBO suffering a 'nuisance trip'. Electrically speaking, there's nothing 'unsafe' about that, so any perceived 'unsafeness' would have to relate to the consequences of some circuits losing power - which happens with any 'nuisance trip'.
Is it your opinion that, say, RCBOs with 'functional earths' are 'unsafe'?
Would it indeed? Would the courts concur?
If my opinion is correct, then no court would be asked whether or not they concurred. However, if my opinion is incorrect, and if the matter somehow got before a court, then I would have to ask the court the same question that I have asked you above.
Given the illegality of it under ESQCR any claim of it being "safe" would seem somewhat foolish.
