Oil radiator down
29 Aug 2011
London
My little plug-in oil radiator went down and I found the fault on the neutral line. There is this thingy that's gone open circuit. Can anyone tell me what is this thing and what purpose does it serve? Also, is there anything else that could cause it to blow other than normal wear? I have had the radiator for about 3 winters. Thanks.
Yes, it's 110C. The unit has a manual thermostat, electrical thermostat, and then the fuse. Given the redundancies, it's probably just the fuse wearing out. Although it was a bit hot for a couple of days. I will get replacement fuse and thermostat. The manual thermostat seems ok because the on/off click is easily audible and controlled. In the mean time I think I can run it without the fuse but with attendance. Even if the electrical thermostat doesn't work, the manual one should. Everything is inline.
I have crimps. Even if I didn't I can use cut up spade connectors to use the crimping bits. Solder should work for relatively low temp stuff like this. The easy melt solder needs 180C.
Put some sort of heat sink, on the lead, to prevent the heat spreading along the wire. It was normal practice, whilst soldering germanium transistors. A bit of wet cloth will do it.
A mini vise grip (mole wrench) clipped to the lead, if you have one.
Ah, germanium transistors…… probably Made In England too!
Or combination pliers but might take a bit of practice unless experienced.
