Can't you guess?Where did you see that?
The OSG sayeth ....
The OSG sayeth ....
This is related to gas though?
Can you clarify why building control would need to approve this?Quite So
But the BCs around here will refuse to issue completion certs without ventilation requirements met. Woking are especially pedantic about fire alarms too. The problem the uk has is there is too much vagueness at the centre so this emanates out wards and hence the plethora of interpretations
It is. However, EFLI asked "where did you see this" and I suggested that (since no such reg relating to water/pipes exists, he might guess that someone had seen the material I quoted about gas pipework and had (incorrectly) extrapolated to water/pipes from that!This is related to gas though?
Keep it like that. Extra fan not needed.Can you clarify why building control would need to approve this?
I’m not planing on applying to BC…
There are distances in 7671 that you must adhere to and those are in the gas regs too.
Yes but, as has been said, the question was about water pipes, not gas ones. I merely suggested that whoever came up with the suggestion about regs regarding water pipes may have read what the OSG says (citing gas regs) about gas ones and 'got themselves confused' by thatThere are distances in 7671 that you must adhere to and those are in the gas regs too. ... When we had a new gas fire put in in the lounge, I dragged a new feed in for the lighting. They were very careful to make sure the cable was the minimum distance from the gas pipe.
What "Building Regs Recommendation" would you be referring to?But as far as the 300 that was mentioned, I think that would be referring to the building regs recommendation of distance between sink/ hob and outlet/ switch .
Hmmm. Well, the OSG is the OSG, and quite often has a mind of its own, and I think the 'minimum and maximum heights' came from Approved Doc M (not the actual Building Regs), didn't it? - and I'm not sure about this 300mm business (although I don't recall having seen it in any actual 'regs'.I can't find my latest 17th Edition OSG, but there was something in there about building regs requiring minimum and maximum heights and also there was mention of a 300mm minimum distance.
Had to dig for this.
I have print out of it from the very beginning of Part P.
It is just guidance from Paul Cook, but I'm sure it made its way into the OSG at some point.
But yes, you're right, it was never in 7671.
Some things in 7671 are not specific. They are left to the readers interpretation.
part-p-special-locations-and-kitchens.pdf https://share.google/p8TRYNaWS8ZFWSu8b
