Fair enough but, as has been said, that doesn't alter the situation about 'mixing' (or the lack of it .... .. rough calculations assuming 'perfect' insulation (zero heat loss to environment) ...Mine just has the sprayed on insulation but it doesn't change the fact the change only occurs when used earlier.
.... most nights, the (3 kW) immersion is powered (under thermostatic control) for a total of between 1 and 1.5 hours. Assuming that water is being heated from, say, 18°C to 62°C, that implies that I am using around 58 - 88 litre of hot water per day, so that is the amount of cold water which would exist at the bottom of the cylinder at the end of the day (just before heating re-started).
If that cold water (assume 18°C) had fully mixed with the remaining heated water (assumed 62°C) then the water available from the cylinder at the end of the day would be between 34.5°C and 43.8°C - dramatically lower than I actually experience. I therefore conclude that minimal mixing (or any other process of raising the temp at the bottom of the cylinder) is occurring
