Thanks everyone.
How long a fitting can you accommodate?
As I said before, 440mm. I made a booboo, though, they are not 18W tubes (otherwise they'd be 600), they are 15W.
The picture above shows extra space above and below the fitting, but the one on the right hand side has a shaver outlet immediately above it, so putting a longer fitting in is a no-no.
Osram LED Tube T8 (EM/Mains) Standard Output 5.4W 650lm - 840 Cool White | 44cm - Replaces 15W starting from . Order ! Free LED-Advice: !
www.any-lamp.co.uk
I'll have to take out one of the fittings and see how it's arranged. Having looked at the reviews, a couple say it comes with a starter, but as far as I can see, these ones are HF.
Hey Simon have you considered some LED strip stuck to the back of the cabinet compartments where the existing strips are mounted? It’s fairly easy to source strips rated at 5W per meter and looking at your cabinet it wouldn’t be difficult to fit 3 linear meters of strip in there running up and down so all the light is directed at the diffuser panels. It’s also easy to source your preferred colour temperature of light.
Hi Rob, long time no talk, hope you're doing well mate!
Funnily enough, I did think about strip, but then I wondered how to attach them. It looks like there are two mounting points behind the flu fittings, but I'd probably need a strip of stainless plate or something similar to attach them to.
Not sure I'd be able to get 3 linear metres in, though. The frosted area in the side panels is 400mm tall.
Again, I'll have to do some deconstruction to see what's what.
Yes, I might add that when trying to replace existing lighting (either filament or fluorescent) the converstions of equivalents in lumens and colours and spread etc can be a bit of a complicated trade off. At best a guess, then take your best guess and fit a temporary next guess accordingly and then you might find your 2nd to 4th guess might be the best compromise in practice . good luck.
Yeah, I was fearing it might be a bit of a guessing game!
I'll post some pics when I have deconstructed things a bit.
