Its a worchester bosch greenstar 4000 and it came with the bosch easy control thermostat so its the correct thermostat. The app seema to be running fine and i have set my scedules and its kicking in when it shouldMy radiators will also take a long time to heat, it depends on the lock shield valve setting, and the TRV heads, and how long the boiler runs for. My thermostats are set to oil, so depending on the thermostat used it may need setting to gas now, but this should have all been done by the installer. Seems he has only done half a job.
so if the room is keeping reasonably close to the setting programmed into the thermostat be it wall mounted or on radiator, then no worries. Hardly matters if top, bottom, left or right side gets warm, as long as it heats the room. I often find radiator is not hot all over, and mine is an on/off boiler, mothers house, the radiators only got warm, that is what they should do to avoid hysteresis.A bit of heat at the top and and bottom not heating. I seen all the rads been bled the temp on the boiler is set to 65 degrees
Do you mean the previous boiler didn't have that problem? Maybe increasing the pump speed would help, if it's an option on that boilerWe had a new oil to gas install yesterday and the rads are not getting that warm. A bit of heat at the top and and bottom not heating. I seen all the rads been bled the temp on the boiler is set to 65 degrees
I’ve seen a chimney sweep mode on my Vaillant EcoTEC plus 418. What does the chimney sweep mode actually do? Does it give the boiler/burners a good clear out or is it for something else?Press and hold the ok button on the boiler display panel then put the boiler into chimney sweep mode. The boiler should now run for 10 minutes at full rate.
It’s to check the CO/CO2 combustion is within the range required for the appliance. It’s normally done at a maximum and minimum setting. Cleaning the heat exchanger requires a bit of elbow greaseI’ve seen a chimney sweep mode on my Vaillant EcoTEC plus 418. What does the chimney sweep mode actually do? Does it give the boiler/burners a good clear out or is it for something else?
Maybe in my circumstances the boiler is taking into consideration the outside temp and the internal temp and is not firing fully to bring the heat up as its worked out that it does not need to fire fully to get to my desired temp
