- Joined
- 27 Jan 2008
- Messages
- 29,219
- Reaction score
- 3,582
- Location
- Country
Anybody reading this thread who is like me - know nothing about electrics, how it all works - and is unable to get their head around the idea of plug-in solar, I found the below link pretty helpful in explaining in simple terms what it is, how it works, and why it is not yet ready.
Of course, as I know nothing about electrics - I also cannot say how accurate the information is.
https://solarenergyconcepts.co.uk/post/plug-in-solar-uk/#amendment-4
Cannot "a problem similar to what is shown" not equally possibly arise even if there are NO 'plugged-in' solar panels, the possibility of cable of one leg of the ring being 'overloaded'depending only upon the magnitude of the loads and how close they are applied to an end of the ring (e.g. 40A worth of loads applied close to one end of the ring in your diagram) ? ....I have looked at our ring final <diagram> and what could happen, remember some homes only have one ring final, but with the old BS546 15 amp socket, we would have multi-circuits and still likely 20 amp cable, with 15 amp fuse, so what is shown is unlikely to cause a problem simular to what is shown, the same applies with continental system, it could still happen, but less likely.
We have to use the ratings of the protective device, yes I know we can draw more than 32 amp from a 32 amp RCBO, but not for an extended time. So with 40 amps the RCBO should in fullness of time trip. Fullness of time meaning before the cable overheats.Cannot "a problem similar to what is shown" not equally possibly arise even if there are NO 'plugged-in' solar panels,
So to get people to only have 800 watt of solar, will save the government a lot of money as once they have 800 watt, unlikely to replace it with 6 kW.
If everyone did as I have done, and fitted 6 kW of solar panels, at today's tariffs, there would be a major problem, as my net cost for electric for 10 months is around £200, and dropping, they need to get people to fit smaller arrays, or there will be a problem, so get the builder to fit 2 kW to new builds, then new owners will not be tempered to fit a 6 kW array.
It is not a clearly cut figure, my roof solar will likely get the sun for longer, fitted Sept 2023 today 12.76 MWh with 6 kW panels so approx 300 kWh per month, divide by 6 times 0.8 = 40 kWh per month x 0.24p/kWh = £9.50 a month or £114 per year.My daytime load is around 100 to 300watts, and so a 800w panel should match it, during daylight, but would it be worth it?
What do you mean by "we have to use"? I was merely illustrating what the situation would be if, with the arrangement you illustrated, one simply removed ('unplugged') the three plug-in solar panels.We have to use the ratings of the protective device, yes I know we can draw more than 32 amp from a 32 amp RCBO, but not for an extended time. So with 40 amps the RCBO should in fullness of time trip. Fullness of time meaning before the cable overheats.
As you have written it, that it surely makes no sense, does it? Whether or not loads could, in some circumstances, 'overload' some of the cable of the ring depends on the locations of sockets within the ring - and if the locations are such that that is possible, then it is surely 'portable' (not 'non-portable') that would present the risk, isn't it?There is a problem with the ring final in that high loads near to origin can overload the cable, which is why it says non-portable equipment over 2 kW should have a dedicated circuit.
Idea is portable uses power for less time, and to overheat needs time.then it is surely 'portable' (not 'non-portable') that would present the risk, isn't it?
Tell that to my fan heatersIdea is portable uses power for less time, and to overheat needs time.
Yes, I was watching YouTube, and reading reports, which seemed to say there was no legal definition on being portable. I have always considered you must be either able to carry it, and that now seems to be 18 kg, although I remember the coal man carrying 112 pound sacks, (CWT) which are 50.8 kg, seems modern man has become weak? Or for it to be on wheels, so the batching plant I worked on, which was transported with 22 articulated units, was portable, like to see anyone PAT test that in less than a day.... and, of course, as I observed before, it seems to be you, not the guidance in BS7671, which appears to make a distinction (in this regard) between 'portable' and 'non-portable'![]()
base left behind, but the thermostat taken when last owners moved out.You may well be right that there is no official definition of 'portable', but that is surely only of relevance to PATesting, since BS7671 does not generally use the term? In fact, "portable equipment" is 'deprecated' by BS7671, in favour of 'mobile equipment', and that is defined as equipment which can be moved whilst still connected to a supply (which, to some extent, is probably true of many thingsYes, I was watching YouTube, and reading reports, which seemed to say there was no legal definition on being portable. I have always considered you must be either able to carry it, and that now seems to be 18 kg,... Or for it to be on wheels ....
That may well be the case, and makes some sense.However, I have modified my ideas on plug in solar, in Europe most homes are rented, so they can't re-arrange wiring to use a small solar array and battery, so the only option is the plug in solar. The same in this country for the rented sector, but with owner occupied, unless exporting solar, non grid tied works better, as it also gives one an UPS supply for selected circuits.
