Ethernet with POE along mains, regs?
10 Jan 2010
London
Dear Sparkies,
What's your view (practical and regs wise) on running one ethernet cable along side some mains in a UK domestic setup?
3 story 1900 house, my switch is in the cellar. I want to run a foiled cat6 from the cellar through a vertical void into the first floor landing to connect it to a WAP on a wall. It will be POE, but the WAP does not require much wattage. In this void (about 3m) between the ground floor and the first floor I also have a few other loose mains running through. Of course no trunking or anything, just usual old house wiring setup.
Didn't think much about it, just perhaps some EMI, but it seems a frequently asked question on the interwebs with differing advice. Some other related info: when my solar installer ran the 6mm T&E from my inverter to the CU, he also added two shielded Cat6 cables in the same approx 6m flexible conduit for future use. I've actually used one of them for Ethernet and get a cool +960mbit on a 1gb connection w/out any packet loss. So pretty relaxed about potential EMI impact on the ethernet connection.
I guess more concerned about regs. Would a future EICR look at this and comment? I assume the risk here is if mains cable and ethernet cable get damaged the ethernet could become live if they are so close to each other.
.... I guess more concerned about regs. Would a future EICR look at this and comment? I assume the risk here is if mains cable and ethernet cable get damaged the ethernet could become live if they are so close to each other.
Other than the possible (but I would think extremely unlikely) EMI/EMC issues you mention, I don't really see a problem, given that (as will be the case) the cables (particularly the mains ones) are adequately insulated for the voltages they will be carrying. Apart from anything else, the chances of both cables in the void getting damaged to the extent that their conductors could come into contact must be incredibly small, trhe activities of rodents being the only possible issue I can think of :-)
I believe that the regs position is that if the network cable's insulation is not rated for 240 V then it should be separated from the mains wiring, i.e. with a physical gap (maybe 100mm?, not sure) or in conduit or trunking. Some network cable insulation is rated for 230 V, some is rated for lower voltages, and most doesn't specify. If you go to the Farnell website page for CAT6 cable:
you can filter by Voltage Rating. There are a handful that are rated 230 V or higher. In practice I'd say there is no realistic danger if you use any other network cable.
My guess is that EMI is unlikely to be a problem. You might have issues if you try to do multi-gig on unscreened CAT5E, but CAT6 with an overall foil screen you should be fine. Good practice would be to not bunch the cables together though.
What would an EICR say? They'd probably want to replace your consumer unit, and change the bathroom light.
