- Joined
- 29 Dec 2025
- Messages
- 4,302
- Reaction score
- 225
- Country
How can you judge it if you don't read it?More is much less. Zero in fact, as nobody reads it.
And if you were born neither the one nor the other or both, or neither?If you were born a male use the male toilets.
If you were born a female use the female toilets.
END OF......
wise up(TM)
END OF......
wise up(TM)
True.If you are a male, just have a slash up whatever is closest when you are "gonna pizz meself".
FUGG'S sake![]()
Arrr s%£t, true dat.....sorryTrue DAT.
FUGG'S sake![]()
Think nosealls talking about mars on the other threadWhere's the clown in the bucket anyway?
I thought he'd be all over this low-brow back and forth![]()
Unless you have a problem:If you are a male, just have a slash up whatever is closest when you are "gonna pizz meself".
FUGG'S sake![]()
0.6% of all newborns are so affected.A micropenis[ (defined as a stretched length (9.3cm or 3.6 inches in adults) can cause difficulty aiming urine, splashback, skin irritation, or urinary tract infections (UTIs).
Urination Challenges: Difficulty directing the stream while standing is common, potentially leading to messy or incomplete urination.
Solutions for Urination:
Sitting: Sitting on the toilet allows better control and reduces splashback.
Surgery: If caused by related issues like a buried penis or meatal stenosis (narrow opening), surgical procedures like a meatoplasty or meatotomy can fix the urinary flow.
That's very sexist of you, women should be allowed to pizz up a tree too.If you were born a male use the male toilets, or pizz up a tree or wherever....
Would you take that sort of approach with those born with cleft palate, shortness of one limb, facial disfigurement, etc?If you were born a male use the male toilets, or pizz up a tree or wherever....
END OF......
wise up(TM)
Yes anyone with a cleft palate, shortness of limb, or facial disfgurment should use the correct toilet.Would you take that sort of approach with those born with cleft palate, shortness of one limb, facial disfigurement, etc?
