Flat is a no go. Apparently asbestos in the property of which, they are planning to remove end of the year...no thanks!
Yea. They said I could rent the flat. No chance.....They are taking the p**s having a meeting to tick a box knowing full well nothings available
Why? Theres asbestos in most properties?Yea. They said I could rent the flat. No chance.....
I knowAsbestos isn't a problem, if it is left undisturbed, or covered over, or painted. Even if not, it is still quite low risk, many of the older members on here, will have suffered serious exposure to asbestos, I know I certainly was.
Because they are planning to strip it all out end of the year. I can't be arsed with all the upheaval etcWhy? Theres asbestos in most properties?
Fair enough mate,.I'd probably still go for it...maybe go away for a break when they do the work?Because they are planning to strip it all out end of the year. I can't be arsed with all the upheaval etc
Throughout the flat apparently. Every room. Even the cupboards and kitchen...It's a foot in the door/a reliable roof over your head, and a big step-up, towards a more stable life. It would be a shame to turn it down.
How extensive is the asbestos? It might just be a single panel in a room, or throughout the flat.
Fair enough mate, if it were me I'd snap it up.....they ain't gonna put you in danger.....you might get a move to a house when the work starts, who knows...
Exactly, no way I'd turn it down.Once in there, you have your base. Spend an absolute minimum on it, until the work has been done, and you know where you are. They may end up moving you permanently, to another flat, to enable the work to be done.
