Some Simple / Small Dry-Lining
15 Feb 2008
Hi forum - grateful some advice please…..
Old house, small and odd shaped rooms - very few plugs, sockets etc.
I’ve a couple of alcoves (one at 600mm wide and one at 800mm widet) that aren’t much use TBH.
I’d like to dry line the end wall only (of both) so that I can run in some new sockets.
In one alcove I’ve had some damp problems (now treated) and the other is in a bathroom.
How far off the existing wall should I space it ?
And should I fill the space with something like a rock-wool or a kingspan ?
Thanks D
Insulated plasterboard stuck on with foam.
Then a few TIMCO plastic insulation fixings.
Foam will act as a damp barrier
Than you @Wayners - that’s so different to what I had in mind.
So stick it directly to the wall an a dot & dab fashion with an expanding adhesive ?
And what do the TIMCO fasteners do ?
I was thinking I’d need some airflow; some battens / framing.
And maybe even a vent top and bottom.
D
Okay - I’ve figured out the TIMCO plastic fasteners.
That’s quite a neat system with the expanding adhesive.
Can I just check something for fear of dropping a clanger.
The wall where I’ve had the damp work was re plastered with Dryzone Hi-Lime Renovation Plaster.
I was advised not to paint it with vinyl based paint to allow it to breath; I’ve used SUPERMATT.
If I use ‘squirty-foam’ adhesive, might that have same affect as non breathable paint?
D
I've user insulated plasterboard over solid walls many times with no problems.
Just needs to be dry with no damp problems.
To your specific job I can't say for sure.
You need to research a bit and decide.
Thank you @Wayners and @foxhole.
A poorly drawn sketch may help…..
The alcove by the chimney (correct @foxhole) is also adjacent to a solid external wall.
I’ve had the chimney and the alcove wall injected / re plastered with the High-Lime.
And it’s in this area I’ve avoided vinyl paints etc for breathability.
I recall (from the damp work) that the alcove wall is a single course of cinder block.
The alcove in bathroom is probably more straightforward.
It faces onto an external cavity (Northerly).
The cavity is small; maybe 50mm at most.
I can see no evidence of damp problems in this area.
The stud wall forming the shower appears plywood faced.
It’s not too noticeable as it only faces into the alcove.
The dry lining I’m thinking about is shown by the red lines in each alcove.
In both cases, this is to allow power sockets and in the bathroom; an illuminated cabinet.
Any advice much appreciated.
Thanks D
If the chimney is damp no amount of damp treatment will cure it. Needs ventilation .
I would postpone until you are 100% sure there are no further damp issues.
That’s a fair point - I’m not in a desperate hurry so wouldn’t be a problem. The damp work on the chimney was a god effort so I hope it works out to be effective. The old shot plaster was hacked off, it was injected, rendered with a good depth of high lime, skim plastered and painted with supermatt. One of the back to back fireplaces was removed and bricked up - leaving a vent. In the other one, a log burner is now installed to get some heat into the chimney structure during colder months.
As you suggest - I’ll wait and see how that all works out.
In the bathroom alcove (no history of damp) where I’d be working on an external north facing wall with minimal cavity; would I be better with batons and breathable insulation ?
Thx D
Sorry for bumping this - but my plans have kinda stalled.
As advised, I’m going to park the alcove (near the chimney) and monitor effectiveness of damp work.
That leaves me the bathroom alcove (picture above) where there is no damp that I’m aware of.
I’d like to fit a (zone2) shaver point / lights etc and get the cables in behind plasterboard.
I’d be working on an external north facing wall with minimal cavity.
I could make this a plasterboard box that comes down from ceiling only to height of wall cabinet.
Full length or short box - would I be better with batons and breathable insulation ?
Thanks in advance D
Not much point insulating it then. Might as well buy a sheet of kingspan and lean it up on a random external wall somewhere for the same effect
Thanks reply.
Just to recap why I said I’m doing this - I’m doing this purely to facilitate cable access not to improve insulation.
D
