If the blade was a different height wouldn’t the grass Ive cut also be a different angle because it looks flat to the ground. It’s not giving any signs as if mower is cutting a slope.Is the blade at the same height on both sides inside the deck
The axle is just a shaft going left to right with a couple of springs.Bent front axle ?
If a springs seized could force it over.The axle is just a shaft going left to right with a couple of springs.
When mower is on the floor I don’t see it bigger one side to the other so I would say this is ok.
Is the distance between the front wheel and the back wheel the same on each side?
Correct as some people help but dont follow post.We've already done that!
You asked to tip up mower on front then rear of which i did but veer wasnt there until i put all 4 wheels on the floor.The deck/frame must have a twist then if wheels have been swapped, tracking is correct its the only possibility left.
