It sounds like the right hand wheel isn't being driven so check for the drive dogs missing or the wrong way round.
If you can spin the small pinion on the axle in both directions, that's the clue. The pinion should freewheel in one direction and grip in the other.
John
If the blade was a different height wouldn’t the grass Ive cut also be a different angle because it looks flat to the ground. It’s not giving any signs as if mower is cutting a slope.
The axle is just a shaft going left to right with a couple of springs.
When mower is on the floor I don’t see it bigger one side to the other so I would say this is ok.
