I had not noticed, but yes, however, it does seem suppliers have been jumping the gun advertising products as being DIY installable which are not.i assume its AI generated as the live and neutral are rather square??
... and no obvious fuse in the plug, either.i assume its AI generated as the live and neutral are rather square??
from Gov.UK so with the firm being named in the press release, one can assume if they say it does not need an electrician they know what they are talking about.Press release was 24 March 2026 said:Retailers like Lidl and Iceland, alongside manufacturers such as EcoFlow, are working with government to enable them to be brought to the UK market.
If something is sold (legally) in the UK which comes with a fitted BS1363 plug, it's hard to see what "needing an electrician" (if such were said to be the case) would/could meanfrom Gov.UK so with the firm being named in the press release, one can assume if they say it does not need an electrician they know what they are talking about.
It seems EcoFlow jumped the gun, and advertised plug and play solar before it has been OK'ed but the UK government, and the advertising complaints people have required them to remove the adverts.If something is sold (legally) in the UK which comes with a fitted BS1363 plug, it's hard to see what "needing an electrician" (if such were said to be the case) would/could mean![]()
That may all be true, but it still would not make any sense of them saying that it "didn't need an electrician" if it comes with a fitted BS1363 plug, would it? How on earth could 'an electrician be required' to plug in such a product?It seems EcoFlow jumped the gun, and advertised plug and play solar before it has been OK'ed but the UK government, and the advertising complaints people have required them to remove the adverts.
Yes, I totally agree with you. Plug and play should be just that, no applications or forms to fill in, and no extra bits which need connecting to meter tails, simply just plug in and it works.it still would not make any sense of them saying that it "didn't need an electrician" if it comes with a fitted BS1363 plug
reading further
So add one of theseNow it's easier than ever to use solar energy! With an integrated inverter and a 5m cable with EU plug, the all-in-one MSW balcony power station makes it easy to feed solar-generated energy back into the power grid. Once installed, monitor the balcony solar panel with ease: Connect via Bluetooth or WiFi to retrieve up-to-date data on your mobile device or PC, so you can keep tabs on all the most important metrics at all times.
and your up and running. The EcoFlow Stream Balcony solar is still advertised, but the comment that it does not need an electrician had been removed, and the lead with 13 amp plug removed from the kit, OK for you and me where we can understand what is really on offer, but many must be buying these kits being unaware they are not as yet plug and play.The principle is fairly simple.Obviously, to pick up the house load, the inverter would need to output at a slightly higher voltage than the mains voltage, otherwise it would not be contributing at all. Unless it were to somehow lead the mains sine wave slightly
Naturally it would increase in both voltage and frequency. As above, to generate you are trying to drive the grid faster and to a higher voltage.When not tied to grid frequency, the output could be deliberately designed to drift high or low, so it is out of bounds, and switch ooff.off.
I'm really surprised at that. I can only assume at least one inverter lacked suitable loss of grid detection and provided a sufficiently stable "grid" to keep the rest online.Overhead supply to 4 properties was cut when the cable was snapped by a fallen tree. The "island" remained energised until engineers shut down the "plug in" solar micro generators.
Indeed, as above.Then it didn't meet basic requirements, in regard to detecting loss of sync,
Perhaps to replace the unidirectional RCBO with a bidirectional one ? Or type A to AC ?That may all be true, but it still would not make any sense of them saying that it "didn't need an electrician" if it comes with a fitted BS1363 plug, would it? How on earth could 'an electrician be required' to plug in such a product?
Rubbish!I'm really surprised at that. I can only assume at least one inverter lacked suitable loss of grid detection and provided a sufficiently stable "grid" to keep the rest online.
Pardon ?Rubbish!
See below ...What do you expect to happen?
Both of which WILL trip any properly designed and configured inverter. That is the whole point of anti-anti-islanding protection - that the inverter will NOT keep running if not connected to a "stiff" grid.The 2 most likely changes will be voltage rise and possibly change of frequency.
Yes, all things that might (at least ideally) 'need to be done'.Perhaps to replace the unidirectional RCBO with a bidirectional one ? Or type A to AC ?
Or add a dedicated radial so you don't compromise RCD protection due to the generation changing it's ability to measure leakage ?
All those come down to the risk that plugging in something like this could leave the circuit with ineffective RCD protection.
Please explain how the inverters can distinguish between the DNO input and the plethora of other inputs when they are all basically a 230V 50Hz sinewave generator.Pardon ?
See below ...
I the case cited, at least one inverter didn't meet that requirement. The DNO should really have given the property owners disconnection notices for their dangerous installations. But I suspect they've accepted that's a lost battle these days.
That was always my worry. The inverters should measure but voltage and frequency and if either goes out of limits auto switch off. But they will auto switch on again as well, so there needs to be a delay between auto off, and restart.A whole new local housing estatel has nominal PV on the roofs and kept going until the sun dropped and tyhat was with "properly designed and configured inverter"s
