While there have been some later discussions concerning TT Systems,Hi all,
I've failed now three times to get even a quotation out of nearby electricians to do this job.
Power comes to my house overhead, and we have a ground earth rod in the back garden. For some reason, years ago, the inspection pit was installed proud of the concrete base that it passes through and the condition is poor in the following ways:
- Rod appears heavily corroded. Perhaps it's fine under the surface rust?
- Clamp cracked
- Whole thing is a bit loose (kids play football out there).
I feel it needs replacing with new one nearby, installed right to ground level ideally with recessed pit. Connected up, and tested.
What am I missing?
If you were being asked to do this job, would you prefer if the home owner had already set the new rod into the ground and just asked you for connection & test?
At the very least, surely a new clamp is needed.
Grateful![]()
I have not seen it established whether the Earthing System involved is TN-C-S, TT or what?
Of course, I am "sticking my neck out" - once again - in commentating on something of which I do not know the actual details.
I am quite familiar with the TN-C-S system, almost universally used in Australia and North America.
(However, I am not familiar with TN-S and TN-C, often used in densely packed towns in Europe and the UK, although I do understand the principles. - See https://en.wikipedia.org/wiki/Earthing_system )
"In the UK, a common practice with TN-C-S is to connect the combined PEN supply conductor to Earth at multiple points along its length between the source transformer and the consumer installation.
This is known as protective multiple earthing (PME).
This is so common that consequently PME is often incorrectly used as a synonym.
Similar systems in Australia and New Zealand are designated as multiple earthed neutral (MEN)
and, in North America, as multi-grounded neutral (MGN),
as opposed to the singularly grounded neutral of, a TN-S or TN-C system."
Now, "Why is this so?"
It has to do with a phenomena known as "Lightning Discharge" - which is NOT the same as a "Lightning Strike".
When Lightning Strikes the Earth, (or, more accuracy), the Earth Discharges the lighting,
there will be a large current within the "conductive" earth which will produce a "potential gradient",
where there will be an almost instantaneous potential difference between points which are only a few "distances" apart'.
While a MEN/MGN system attempts to "even-out" such disparity,
it is VITAL that the Earthing-Path at any "Installation" be of low IMPEADANCE.
While one may think of a "Lightning Discharge' DC, it is an almost "Square Wave" which contains Very High Frequencies.
Hence, the Discharge Path - to any and all Earth Electrode- must be of low IMPEADANCE - NOT just Low Resistance.
Here, I must refer you (once again) to
Good Luck.
(One further comment,
Australian/NZ and North American regulations seem to require that the "Earthing/Grounding"electrode
be as close to the building a possible,
which seems not to be so in the photographs concerned.)
