New 1700mm bath? Plus waste/overflow? These ok??
5 Jan 2009
Hi all.
Fitting a new bath as old one is dirty/grubby and has chipped corner.
I've looked at ones in BQ/Wickes and Selco and was shocked by the quality of them!!!
Very thing and the waste holes were awful!
You would need a tube of silicone and hope for a decent seal!
They are nothing like the one I'm replacing that was cheap
Back in its day but much better quality.
I'm looking at this as it has some description saying it's better than others and it on offer.
I also have a good quality McAlpine waste/overflow but in the past I've seen the overflow holes on baths differ to the fitting itself.
This is the overflow I have -
Any advice guys?
Plus after watching a few video why does everyone ditch the the thin white foam seal that goes on first/inside the bath (or basin/sink) and just use a load of decent sealant.
Thanks in advance.
Bath looks decent enough, the McAlpine waste is also good.
Some use silicone on everything, best use it sparingly, if at all, on things like this.
How do I know the McAlpine waste overflow hole fits the bath listed?
I have read with a decent bath and one of the best McAlpine wastes/overflows silicone is not needed.
But in every video they ditch the thin white foam 'seal' and use silicone??
Cheers mate.
So what is this Lucite Acrylic?
'Not all acrylic baths are made the same! One way that inferior baths cut costs is to use lower grade acrylic. - Rest assured that this bath is made with the very best - Genuine Lucite acrylic. - A beautiful surface texture that feels comfortable against the skin. - Maximum strength, durability and toughness to withstand frequent use. - The highest resistance to everyday wear and tear, stains, and superficial scratches. - The best resistance to Ultraviolet light degradation and household chemicals. Fully Encapsulated Base Board For Maximum Strength'
So it's just a brand name.
They seem to have sold a lot of them and hardly any bad FB except for there where no holees for a 'tap'.
Going to order it.
Another question.
I want to put a seal from wall that goes onto bath.
Seen them but never fitted one.
Bath will be batten supported and sealed.
Wall clad and sealed.
I just want that extra seal as well.
Thanks for the advice mate.
Anyone recommend a seal that on wall and just onto bath.
It goes behind tiles and only provides a small 'lip' to to a seal.
Really not required in your situation with a bath sealed to the wall, then cladding, which will also be sealed.
