Ladder on pitched roof advice
13 May 2005
Lincolnshire
Hello!
I have an extension out the back on an pitched roof thats not overly steep and easy to get onto. Approximately 7 foot above that is he main house roof which is covered in moss which I intend to scrape off.
My question is, will it be ok to use some wall mounted anchor eye bolts attached to the vertical wall, strapped to the ladder.
I'm just thinking if there is a better way that I might be able to use a ladder thats mounted on the pitched extension roof and be safe.
Not sure what you are going to be working on, any photos.
Here
Was going to attach some eye bolts to the wall below the windows to then use to strap the bottom of the ladder too. The ladder will be at an angle obviously and not vertical up the wall. The pitch on the extension roof is about 20 degrees.
Wait for summer , moss dries, dies and gets washed into gutter , clean the gutter.
It wont - I have the same problem and it sort of goes into a dry stasis and stays attached to the tiles until it rains again. Some bits will get knocked off with summer hail ECT.
Here
I have to add that this is very dangerous and you might fall off and die. What I have done in that situ is get some foam and attach it to a flat board then attach to that a built up angle platform with a 2x3 stopper on the back end. The foam grips the rough concrete tiles really well and does not move and the ladder will not slide off the back of the platform because of the 2x3 on the end. The best way to get the moss out of the gutter is with a DIY type wet and dry vac
Here
Nuttiest thing I ever heard.
I'm only going to remove all the moss. It never gets any sun and I'm constantly having to clean out the guttering.
First problem is that the eye bolts might pull out, second problem is that the straps would mean the ladder is wobbly at the bottom end.
Get to the ridge from the other side using a roofing ladder, then pull up another roofing ladder and place it on this side.
But you'll need to be good with heights...and ladders.
If it were me, I'd put up a tower on the ground, fix a bearer to the wall above the flashing, then build a bridge across, from tower to bearer, screw it into the bearer, make a platform, and work from that.
Even then, someone's going to reply to me with...
"This is very dangerous and you might fall off and die"
That's exactly what they did when they came to fit my fibre - only they just used 1 and it didn’t pull out
