How did you become a crash for cash expert, did you take a course on it?Ah yes - I forgot about the 4th category:
d) the inability to accept that you fell into one (or more) of the first three categories.
I see you work in insurance. You read from the same script.a child, an animal etc. in the road. You should be able to react to such events in a timely manor.
Yes, just enough for us to all know where we are. Thanks for your contribution.I think I've made my point.
I have already told you the reason why: inappropriate fluid. How do you think you will do:
You should be able to use any fluid with your EV. Once it sets itself on fire, the fluid won't matter.Is this before or after my EV sets itself on fire?
And why did you say it was due to "infrequent use" when you meant "inappropriate fluid"? Were you lying, or do you just have cognitive problems?![]()
It's an "industrial process". The steps are well defined, and invariant.Oh... is that what they told you too?![]()
In your case, it's both inappropriate fluid (something cheapest), and infrequent use (twice a year).
In your case, that means the cheapest.That's poor advice. It's essential to use a fluid conforming to the specification prescribed by the manufacturer. You really should know that by now...![]()
You may be an engineer, but you have no feel. If you did, you would feel the stuck valves in your ABS as I can over the internet.Ah... but you see, when you're a proper engineer, rather than just an "armchair engineer", you're not as susceptible to the marketing hype and BS because proper engineers understand the specs and what's important. If you were a real engineer, you'd know this too...![]()
That's news to me. I felt no surprise, and was just stating my observations.Yet you seemed surprised and disappointed at the outcome...?![]()
I'd rather use the cheapest brake fluid (of the correct DOT rating) and change it every couple of years, than use the best and neglect it for a decade.
I did not have ABS failure. My car auto rebalances to the other 3 wheels. You wouldn't have noticed a thing.
His name says it all……Why do you keep coming on here and making a fool of yourself with ludicrous claims that anyone with an ounce of mechanical know-how just laughs at?
What you missed is that brake oils of the same spec are different. Since you go for the cheapest, that means your brakes potentially operate on the weaker end of the spec range - say roughly equivalent to 3 wheel breaking on mine.You maybe out to get a grownup to help you read my posts. There you go. I've highlighted the important bit that you missed...![]()
Didn't feel anything because the guy was a trained pro, and left all his brakes off and sufficient room ahead so that he could safely stop without going onto the junction in front of him. My car continued its natural braking unhindered and un-resisted.Of course you can.... I believe you - every word!
The only thing you've "felt" recently, was the back of someone else's car when you drove into it because you're as much of a driver as you are an engineer!
Traction systems are designed to permit slipping on one or more wheels and rebalance braking to the other wheels. A non-braking wheel is same as a slipping wheel. I am shocked you have no awareness of the working principles while still claim to be an engineer. Maybe you are an engineer for bicycles?You can't "re-balance 3 brakes to do the same job as 4 brakes.
