Bolts for Tipo timing belt change
17 Apr 2007
10.2019 reg, 1.4 843A1000 engine
Does the engine mount, water pump, crank pulley or belt tensioner need new bolts when changing the belt?
Those bolts are not typically replaced on any car although the crank pulley and belt tensioner may possibly be required on some models nowadays.
I wouldn't bother unless they come with the replacement parts.
Yeah, normally if they are needed, they usually come in the belt kit. The engine mounting or water pump bolts are never changed.
As above twice.......look for the truth marks on the engine mounting and all will be well.
Have you got the tensioner kit yet? The last one I did came with it's own tensioning two pronged key but I can't remember what size engine it was.
If it has a spring loaded tensioner, check out Youtube for any help there.
John :)
I was quoted kit KP15503XS-2 by the Gates website for the engine. Belt, water pump and tensioner are in the box.
John :)
What are "truth marks"? That's not a term I've heard before?
I assume he means the same as witness marks, basically the clean imprint you can see when you remove an old bolt due to the years of dirt building up around it.
