How to connect 3pin lights to light circuit.
19 Jan 2012
Berkshire
In a charity community centre.... our electrician has installed a fused spur light switch from a lighting circuit for some decorative low wattage LED. lights , which we had not bought, at that time.
But then ....., the ones we bought have a plastic moulded transformer built into a 3pin plug. ....
Is it compliant with regulations to connect a 13amp socket to this lighting circuit because it is protected with a 3amp fuse? .
is there a compliant way to connect this in ? ( there is no 13amp socket near by) Or should we buy different lights .? ..
Yes you can fit a socket to a lighting circuit, it would need to be rcd protected...but im guessing it already is (maybe) as its new work.
There is no regulation prohibiting putting a 13A socket on a lighting circuit. However,
* you should be aware of the risk that someone overloading said socket could take out the lights. To mitigate this, you may want to install the socket inside an enclosure that requires a tool or key to open.
* all socket outlets need to be RCD protected, on an newer install it's likely that all final circuits are RCD protected but on an older one they may not be.,
Thanks , the enclosure option sounds good ..
I’d be more concerned about the hazard those lights pose
I've been using lights running on units such as that for a long time and currently have something in the order of 4-5Km of lights, they have proved to be the most successful and reliable style by far and to date I've had faults on only 2 strings of lights, the power supplies/controllers have been totally reliable and registered with my public liability insurance for at least 10 years.
So what am I missing?
