Nonsense.They'd be OK on concrete or on compacted rock, but not spanning the two.
It's a pathway. What problems do you envisage?Understood, thanks. Also, going ontop introduces the DPC issue (above one, below one, granted).
Ive got a decent large grinder, I think I'll cut a straight edge along the foundation pad 4" and lay flush with the top of the foundation. Seems to be least likely to cause future problems.
Cheers v much.
I did wonder about that. But then drainage for the gravel bit becomes tricky.You could go a bit higher, then cover the concrete with a bit of 10mm gravel. Would look lots nicer.
How is a cut with an angle grinder going to help with that?Just splashback soaking through the brick and making the inside wet.
I've already suggested that.If he's that concerned about damp he could always splash a coat of anti damp seal on it...
the umbrella too?I've already suggested that.
