I'm honestly staggered that millions of motorists aren't clogging the sides of the nation's roads daily, their cars on jacks (or blocks of wood), as wheels are evidently as good at holding air, as a football sock is at holding soup......
If you have no leak problems, why do you have such great interest in these threads? Go watch TV, or something.I'm honestly staggered that millions of motorists aren't clogging the sides of the nation's roads daily, their cars on jacks (or blocks of wood), as wheels are evidently as good at holding air, as a football sock is at holding soup......
The bead sealant will be suitable, but not not in the way you know. The sealant must be cured before tyre mounting.
For me, slow leaks are a persistent problem.
Never too late to learn.![]()
Bugger! Me and every tyre shop I know have been doing it wrong for the last 30 years. Why couldn’t you have trained us 30 years ago?
I don't need all the personal details, though. Thanks for your trust. I am healthy and haven't had a chance of looking into DIY doctoring. Otherwise, I might have started a thread on it.Try Kegels![]()
If onlyBut the final solution is at hand.
The fuel solvent on roads will destroy them
That's the first sensible thing you said in these threads.Only if you run your wheels without tyres on them..........
Makes sense. The inside of the tyre has been preserved like an Egyptian tomb for the last 22 years.That's the first sensible thing you said in these threads.
Yes, it's a clean room environment inside the tyre. The 22 year old tyre is brand new on the inside. Hence I see no reason to buy a new one until I need to go on the road with it. Still, I prefer high temperature paint for this application. The closest thing I can imagine to work is the engine enamel. The temperature tolerance of domestic paints are generally lower.
Sounds clever, but not. From product description:Makes sense. The inside of the tyre has been preserved like an Egyptian tomb for the last 22 years.
I'd probably go one step further though and use exhaust manifold paint. If the bead seat ever reaches 600°C you'll be very pleased you didn't cheap out with engine enamel.
