Damp walls on extension
I went back and checked some of the things you guys mentioned.
1. I knocked off some plaster on one of the damp internal walls and found the brick also damp:
2. I took some photos showing more of the outside of the building:
View attachment 357643View attachment 357642
The internal wall of this side of the building is where the damp goes up around 2+ meters:
The roofing felt was overhanging, but I could not tell if it would be catching water that could then be getting inside
3. I was thinking the damp could be being casued by the pebble dash breaching the DPM, but then I noticed that on one side of the exstention building it does not have pebble dash, yet that wall is still damp on the inside.
The wall without peble dash:
then on the inside of the wall above it looks like this:
-In the photo above I removed the radiator pipes boxing. I checked for leaks on the pipes but they seemed ok. Yet the wall is very damp, even though the outside of this wall has no pebble dash on it. As mentioned previously, the wall connecting the main building to the extension also has some damp at the bottom of the wall.
It's damp because it's a low end poorly built, zero cavity, zero insulation structure.
It need several thousand quid spending on it, to bring it up to snuff. Just about every façade or elevation need work doing to it.
Do those roof tiles have enough overlap? If water was driven up underneath.....
There seems to be felt, but it's not clear what happens at the verges
  • Thanks
Reactions: DM7
is there any type of covering that could be put on the internal walls to at least keep it damp-free on the inside of the building? (as a cheaper alternative to sort the issue out for him) and if so, would the dampness underneath it cause any further damage to the extension over time?
He had originally asked me to install damp-proofing rods in the walls, but I said I wasn't sure if it was required and I didn't want him to waste money on things that wouldn't help him sort out the cause problem.
What is the wall construction?
Is it solid, cavity. Cavity with insulation?
You could start by clearing all around the outside, maybe removing a foot width of the hard standing and forming a French drain with a perforated pipe discharging into the gully.
Inside I can’t you have any choice but to strip off the plaster, isolate the damp and plasterboard over.
You could just put say 50mm of celetex against the wall, tape all joints, then 50 x25 battens flat then foil back plasterboard.
If you don’t to insulate then there are isolating membranes that can be fitted before re plastering.
I suppose you could fit wall rock dampstop wallpaper over the plasterwork, it’s a bodge but your only other option is stripping the plaster off the wall
  • Thanks
Reactions: DM7
I need to go back and find this out. I'm not sure what the easiest way to find this out is, as I don't think he has the drawings from when the previous owner had the extension built.
Its needs knocking down and rebuilding, the dpc whatever it was has gone and its sat in a bog!
So I forwarded him the info from this forum chat, around the time youse all gave your suggestions, and I gave him a link to this thread so that he could read through all your comments.
I told him its not really a job I wanted to take on, and now I only do plumbing and electrical work, so I wasn't feeling to take on building a tench and doing any of the other things you guys recommended, and I said to him to look around for someone who knows more about this topic, and to see if they can advise and do the works for him.
He messaged me yesterday and asked what I think about putting damp-proofing rods in the wall, but I wasn't sure if they would solve his issue.
Do any of you guys know if they are suitable for the type of damp issue he has?
No.
