Meter Reading Change for our Freehold
Oh yes, Henleys were around.
But the meter fitter didn't have any space for them.
Fair enough - but, as I've said, I don't recall having seen them (or anything like them) in the pr-CU/DB days.
My recollection is that, back then, when there were usually multiple CI 'switch-fuse' rather than CUs/DFBs, the 'norm' was to have each of them fed directly from the meter, rather than having one set of tails for the meter which were then 'split'. Was that not the case?
Yes it was the norm.
And it is currently not rare for modern installations, however with the proliferation of 25mm² tails becoming the standard (even for 60A or smaller supplies) and more difficult to fit a second wire it is becoming rarer.
But how does this change the question, smart meter or not? I was also asked by British Gas, and in the end realised I needed one to be paid for export, but other than that, the change has just meant I can no longer read the meter. I know how much I am using with the app, but down to nitty-gritty, the meter does not show anything without pressing buttons, and no instructions left as to what buttons to press. It should not be rocket science, it only has two buttons. But meter before did not have any, it showed a number, and you made a note, and took old number away from new number, and you knew how many kWh you had used.
So I have
so expect meter reading somewhere around 7857 at the moment. So looking at the meter
Which does not seem to line up with anything shown on my bill. But the bill says
So not really worried, although being charged VAT when it is a minus figure does seem a bit off. As far as I can make out, the meter reading is for export.
However, I would not want to authorise a smart meter which I can't read direct with a shared account.
Yes it was the norm. ...
As I said, that was certainly my recollection
... And it is currently not rare for modern installations ...
It presumably cannot be particularly common since (a) a high proportion of installations have only one thing (a CU) fed from the meter and (b) even when there is a second CU (or a second 'something') the two or more things would very commonly fed via tails that were 'split' in a Henley/whatever?
... the change has just meant I can no longer read the meter. I know how much I am using with the app, but down to nitty-gritty, the meter does not show anything without pressing buttons, and no instructions left as to what buttons to press. It should not be rocket science, it only has two buttons. ...
As you say, it's definitely not rocket science. If you haven't managed to work it out by 'trial and error' (which I would have thought would be pretty easy) the instructions (which tell you which buttons to press) must be pretty readily available.
Maybe what you need is the services of a 5-year-old - who could probably work out the buttons for you pretty quickly ;)
I must have worked in an alternate universe because I have seen numerous installs over the decades with a "main" CU (4 or 6 way Wylex Standard) and 2 or more 1 way Wylex units, fed into the meter.
Yes, I've seen that, too, but it's not really the 'pre-CU era' (i.e. 'post-switchfuse era'), because, although not cast iron, those 1-Way Wylex units were essentially just a manifestation of those previous CI switch-fuses, under a new name.
How often have you seen two or more 'multi-way' CUs each fed directly from the meter, and have you seen that at all in installations that have moved beyond the Wylex Standard era?
I'm not quite sure what you want from me, or what you are trying to prove.
I started in the industry in 1983 and in that time must have seen countless thousands of consumer unit arrangements.
Among these have been all sorts of Bill/ GEC/ Crown/ MEM style switchfuse type units and Wylex Standard units from 1956 onwards and the later 1980s and 1990s MCB boards of varying sizes, with tails also if varying thicknesses, both wired direct into the meter and via Henley blocks.
AFAIR, the Crown units were actually introduced after the Wylex Standard in the late 50s, circa 1959.
I certainly don't "want anything from you" and nor am I trying to prove anything.
... I started in the industry in 1983 and in that time must have seen countless thousands of consumer unit arrangements....
... which obviously trumps me, since, as you know, I've never been 'in the industry' at all!
However, I've seen a fair bit over the years and decades and, as I've said, in the ancient days of CI switch-fuses (on which I was 'brought up'!), it was very common (probably 'the norm') for them to be connected separately and directly to the meter. However, I've also said that (obviously with my limited experience) I cannot recall, more recently, having seen two things that resemble 'modern CUs' separately/directly connected to the meter. I certainly have seen plenty of cases in which a small (usually 1-or 2-way) 'CU' has been added to supplement the 'main CU', but that has always, or nearly always, done by splitting the meter tails with Henleys/whatever, not by feeding them (as well as the main CU) directly from the meter.
So ... I've merely been reporting what I have, and have not, personally seen (in the context of my limited experience', rather than 'wanting something from you' or trying to prove anything ;)
I'm of the same opinion and similar experience as secure and I'm tempted to go back and count the number of times you have made you 'never seen it' type statement and asked the 'does it still happen' question... but it's not worth it.
The simple fact of the matter is it's significantly less common than it used to be but still very much still alive, it's one of those things that is common enough that it would not occur to me to mention it nor take a picture.
However a thought had just crossed my mind that a friends (Fred) naughty landlord had been stealing Freds electwiccy so I checked the pics but sadly he had added extra tails to the VOELCB incoming terminals
May be, I will go down and push the two buttons, and never seem to get the same results twice.
To be frank, not that worried, the app tells me what I need to know, and I have the solar software which seems to confirm the readings are correct.
But, why fit a hard-to-read meter if you don't need to?
I certainly agree that one should not have to do that, or be expected to do that, but I'm not sure it's quite as difficult as you make out!
My 'dumb' meter has buttons to push in order to display the umpteen bits of data it stores, and I rarely remember exactly what I have to do to see what I want. However, as I cycle through the various 'numbers' by pressing buttons, for each 'number' the display tells me what it is that is being displayed, so I know when I have got to what I want.
This 'added difficulty' is really an inevitable consequence of the escalation of the amount of data there is to display. Once upon a time, a meter only had to display one or two numbers, so it was very simple to read, but these days there can be dozens of bits of data. It's a bit like TVs. The first one we had was either on or off (BBC only), so 'control' was very simple. then we moved to one with which we could choose between BBC and ITV, so a little more 'controlling', and then one that offered BBC, BBC2 or ITV. However, these days there are 'hundreds' of channels to choose between, so the choosing/'controlling' is inevitably a somewhat more complicated process than it was 'back then'!
One of the sites I rent, one of my commitments to the landlord since 1998 (I think) has been to take 3 monthly meter readings for them, in the old days it was easy and when the smart meter was fitted (bit of a surprise) I scrolled through about 8 readings in order and noted them in columns in the log book
May be, I will go down and push the two buttons, and never seem to get the same results twice...
I don't always see those same readings in the same sequence, additionally the lead & lag and/or 3rd & 4th rate records are not always there.
The book has got in a bit of a mess as it's very easy to simply press the button and jot before realising the error.
Maybe 'not worth it' for you, but worth it for me if I'm interested in knowing the answer to the"does it still..." question. Why do you think I would ask a question if I was not interested in the answer?
.... The simple fact of the matter is it's significantly less common than it used to be but still very much still alive, ...
I don't think I've been doing nothing different from secure and yourself - namely reporting what 've seen (and not seen) over the past 60 or so years. However, unlike some, I am not making assertions about 'how things are' but, rather, am merely reporting what I have personally seen (usually with caveats about my limited experience/exposure).
This is exactly what I have found, I am sure if I pressed the button enough times I would get the right readings. As said it is not that important to me, as the app is telling us what has been used or exported, but if I had to give the reading to someone else, having a smart meter is hassle I simply don't want.
