- Joined
- 28 Nov 2023
- Messages
- 49
- Reaction score
- 2
- Country
Hello all,
I have an ancient Cistern syphon (see attached photos IMG_9460, IMG_9461), which was seen by a plumber 4 years ago, because the WC handle became difficult to turn. I had wanted a new syphon but the plumber took a look at the crack on top of the handle (IMG_9462) and declined to replace the syphon. Instead, he squirted some WD-40 around the handle, and this solved the handle turning problem.
For the last year or so, the syphon has started to leak appreciable amounts of water into the commode (see IMG_9459). This problem now causes my water bill to be 60% higher than before and I am keen to replace the syphon with a new one to stop this leak.
Please advise me on how to remove this faulty syphon and replace it with a new one. I already have a Dudley Turbo 88 syphon (IMG_9464) which I bought 4 years ago, just before calling in the plumber, if this is suitable. IMG_9466 is my best shot of the cistern base.
Incidentally, the photo IMG_9467 shows that there is a gate valve between the loft water reservoir tank and the WC. The top of the pipe containing the valve, goes to the loft water tank, then moving down this pipe we reach the gate valve, then the connection to the WC, and finally it (the white PVC tubing at the lowermost end of this pipe) goes to the bathroom adjacent to the Loo.
Many thanks in advance!
