Workshop Mk2
Thanks Andy. Though I fear the end is far away still. But....
The door is in and glazed
And I have the insulation for the exterior walls
The flashing is all in around the foundation insulation. Clearance is clearance is clearance I guess?
It may only be 20mm think. But the cuboid cave is insulated on the walls. Yay. Now I'm hoping for some cooler weather to get the muck on. Until then, time for some electrics.
It's too hot to render.
Can't roof until walls are finished.
So it's time to start electrics.
So far trunking is in (few more fixings needed) and I've started routing the light conduit.
Conduit in piers all mostly line up with the metalclad... Mostly
Couple of cable outlets to add for the tools and the CU needed, then can get the reels out.
Let there be light!
I'm a big fan of this ;)
It's all wired back to a single flex on an IEC plug
And the ring is in. It's been a long time as a building site, then a cave, but finally it feels like a building.
Looks fantastic.
Possible suggestion. I put an emergency light (connected to light circuit) in my windowless workshop. Decided that if I tripped the lights, with saw still on, and floor covered in trip hazards, I wanted to be able to see route out and where door handle is.
Looks fantastic.
Cheers SFK, I've considered it. All circuits going to be on RCBOs, so likelihood of lights tripping out is minimal.
That said, accessable conduit wiring, I can always add it in. Need HVAC/environmental finished first then security
  • Like
Reactions: SFK
Yup, it's very minor and doesn't span the slab width. About in the middle too, between the piers.
I'm assuming it's the walls pressing down around the perimeter, hopefully just a settlement crack
I was going to say if it was the floor it’s not big enough to worry about.
