Menvier TS2400 - reset HELP
What’s coming out of in Volts DC
Battery leads ( battery disconnected ) inc psu
Aux volts inc psu
Network bus
away from home will check when i return and post back, thanks
ok thanks, but what does this mean? I have a multimeter and changed all batteries and still get the menvier security version 4.1 screen on the panel
...any help greatly appreciated
More pics
11 volts ? That’s too low …I would wire the keypad direct onto the panel network with nothing else on the network to see if it works it could be one of the data lines down to the keypad …
Did you wire it onto the network at the panel ?
yes did this still dead. so the alarm bell outside goes off when mains power switched on, however when switched off nothing happens...not sure if the back up power is getting to the panel...
