Fitting an isolator between meter and consumer unit.
"Second" to what?
I decided I'd like
a) to be able to install a CU with the incoming tails isolated.
b) to have a single point of isolation for the entire installation.
The isolator in the main board is considered to be “main isolation” which isolates the installation
Isolating the supply into the main board is not necessary to achieve main isolation
Unless there is a Henley block.
In my rental agents contract it states a single point of isolation which can be tricky with E7 systems.
Well Im not familar with Henley blocks before main boards as i don’t live in the uk
A main switch in a main board provides main isolation as far as I know
Offering advice on something you don't know about can be very dangerous
Anyone taking your advice would have every expectation that any advice you do offer on the basis that your declaration of
should be appropriate, correct and safe.
I'm curious as to why you would have them after the CU?
CBA to draw this*, but what I have:
Tails from the isolator after the meter go to Henley blocks (actually Lucies, but NM).
They supply:
  1. Switchfuse for garden outbuilding
  2. Mini CU for a light and a socket in the CU cupboard to use if everything else is off
  3. An enclosure with a switch (part of an SPD) through which the supplies into the CU run, via DIN rail distribution blocks in the enclosure
The switch in (3) is the one which will isolate the entire CU. The CU has no "main isolation" function in it, just 3 RCDs and a switch for a non-RCD section, each connected to the distribution blocks in (3).
Without the isolator after the meter I would have nothing which would turn everything off.
* Although I should, for documentation purposes. :oops:
They supply:
If there is no main switch in the enclosure you call a CU then it is a distribution board and not a CU, furthermore IIRC from previous posts threads; it should not be under the control of 'ordinary people' or whatever the official regs term is.
Apart from
My meter has a switch on it,
Why 'Oh dear' when a CU has a main isolation switch?
Why 'Oh dear' when a distribution board should be under the control of qualified (or whatever the official description is) person?
You are one who often 'corrects' others comments.
Single pole.
Ah well you didn't inform us of that detail, it's not a facility I've encountered, those I've worked with have been 2 and 4 pole isolation.
No comment.
No comment.
Sorry.
It can be difficult to achieve a single point of isolation for many installations. I think most of us would accept an isolator for the “normal” mains supply and another isolator for “off peak” etc as being “relatively close to what should be achieved “ yet not quite there in reality.
If we reckon “what can I reasonably do?”
We might able to sleep at night.
I’ve seen lots of installs with “Henley blocks” (other makes are available) and you can easily be presented with a host of switches to be switched to isolate the whole lot.
Compound that with some isolators being opposite up/down orientation for On/Off and you get the real risk of thinking you’ve achieved it but you’ve not, bad enough for an ordinary person but can even catch out the Electricians amongst us for a few seconds at least.
A lot of installations might be such an age that we half expect to see a knife switch stuck on the wall
