Interesting Regulation of Yesteryear
I wish you'd explain what you think they did mean.
I suspect they meant that sockets, light fittings, etc should all have switches so that they could be isolated without having to isolate the entire circuit, or functionally controlled in a practicable way, and that they assumed that common sense would prevail. :oops: This was in the era when best practice advice to skilled artisans was morphing into definitive prescriptions and proscriptions aimed at those who were less than skilled artisans.
As per my first point...please do explain the difference.
You may not believe it a question of what you think the difference is, but you are advocating very strongly for it, so please unravel it for me.
Basically "every" relates to every member of a group as a whole, and emphasises the group as a whole, and "each" relates to them individually.
Yes I guessed that but when was it removed, I thought perhaps it was a throwback to then.
Just gone through the 14th Edition, 1966.
A58.
An appliance or lighting fitting connected to an installation other than by means of a plug and socket-outlet shall be controlled by a switch or switches which shall be arranged to disconnect all live supply conductors.
For an appliance fitted with heating elements which can be touched or into which more than one phase of the supply is introduced, the switch shall be a linked switch arranged to break all the circuit conductors.
NOTE:- For the purpose of Regulation A58, a circuit-breaker may be used as a switch; and a bell transformer is not regarded as an appliance.
Two points here from a personal point of view... This is the first appearance of circuit breakers I have seen in the regs. IIRC, the BS for 3871 hails from 1965.
Second, although not classed as an appliance, I have seen many bell transformers with an adjacent light switch for isolation. Indeed, that is how I was told to install them myself, when I started in 1983.
You'll have to wait for the next thrilling installment as to whether I can find anything in the 15th Edition, 1981...
Chances are, the answer will be no, because the index makes it so hard to find stuff in the 15th onwards, compared to previous Eds.
Indeed, some might say that "Any conductor/part that (normally) carries current as part of its intended function is considered "Live" such as switched L or perm L or such as N (by convention only a shared E & N such as a PEN (CNE) is not considered Live! "
I am not convinced that exception convention is the best of ideas really.
When did live include neutral? I know neutral and line are classed as live now, but was that the case back them?
Not sure if they're talking about the neutral being a live conductor or whether they were referring to "more than one phase" in A58.
Don’t think neutral is included in live conductors
They refer to switching all lighting live conductors which presumably has never included a neutral ?
An appliance or lighting fitting.
So could include a neutral.
Stop would ya :D
That means lights and appliances must have all live conducors disconnected
So lighting therefore would need the neutral switched if the definition of 'live' includes N at that time
Anyway I just noticed and somebody else I think already said
The rule says a CB can be used as a switch so therefore it can only be line/phase
OK, if the appliance has heating elements that can be touched (like the old open element wall-mounted fires), or an appliance fed by more than one phase, the switch has to break all the circuit conductors, ie live(s) and neutral.
Anyway, I'm off to dig out my copy of the 15th, 1981 to see if that reg lives on!
So what we now call live conductors, back then, was called circuit conductors.
I seem to remember there were a few odd things, the regulations were more like the guides we get now. Seem to remember a distance socket to a sink, I know last house it was around 3 inches between socket and the sink, it powered the waste disposal unit, so being under the sink there was no real issue, but father-in-law (whole family on the male side seem to have been electricians) thought not allowed, and I went through BS7671:2001 and could find nothing about sinks and distance.
I also seem to remember a maximum length for a kettle lead, which was linked to distance from sink, so one could not fill the kettle without unplugging it.
