Been keeping my mouth shut as best I can when a lady engineer from the water board was telling me that the hours of screeching from their street stopcock was caused by my pipework 'water hammering' (or two pipes rubbing together) when no water was being used. When she (reluctantly) replaced the non return valve in the street stopcock and fitted a new meter, the 'water hammer' stopped. She couldn’t explain that except for saying that it will return. I hope she is wrong about that!
Not a problem I've ever experienced in my house, but having worked in hundreds of other houses, the problem has always been the Torbeck Valve on one or more toilets. (plumbers diagnosis not mine). There's no way of telling where the noise is coming from, the screeching noise will travel throughout the house like a screaming banshee and manifest itself a long way away from the offending valve. Never heard of any other cause.
Sometimes you can get away with just replacing the rubber diaphragm but the complete valve is cheap enough.
edit: a water tank in the loft can have a similar valve.
